  • 1 year later...
On 12/29/2023 at 10:50 PM, Photoworks said:
Same here. Godox pb 960
but be aware of flash overheating in rapid fire
Can you elaborate - how fast is rapid fire? And if the flash overheats, it will continue to work after some time? (sorry for the questions, but I am a flash-novice...).
During normal use, the SF-60  does not overheat.
If you put the flash in a softbox at full power, it will slow down to prevent at prevent overheating. That is real for most brands that are battery-powered.
The Godox battery works on the SF-60 with the Sony Cable ( to confirm, but I think it said in the manual too)
I use the same powerpack on the Godox V1 pro II
  • Thanks 2
