ChrisP08 Posted December 28, 2023 Share #1  Posted December 28, 2023 Advertisement (gone after registration) I just picked up a Leitz format 1c this past weekend for my home darkroom. Could anyone tell me what this numbered knob is for? I've only used a Beseler 23c iii so this is new to me. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/386420-leitz-focomat-1c/?do=findComment&comment=4964894'>More sharing options...
Advertisement Posted December 28, 2023 Posted December 28, 2023 Hi ChrisP08, Take a look here Leitz focomat 1c. I'm sure you'll find what you were looking for!
maxspbr Posted December 28, 2023 Share #2  Posted December 28, 2023 (edited) The Ic is a wonderful enlargement! It’s a pleasure to use it. The piece you’re asking about is to indicate degrees of enlargement. 2x, 3x… 10x (them an image projected of 24x36cm). It must be linked with the head of enlarger. When you change the position of it the piece will show the new enlargement rate.  from a 1950s folder on Ficomat: Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Edited December 28, 2023 by maxspbr A photo! 1 1 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/386420-leitz-focomat-1c/?do=findComment&comment=4965229'>More sharing options...
M.Hilo Posted December 29, 2023 Share #3  Posted December 29, 2023 On 12/28/2023 at 11:36 AM, maxspbr said: The piece you’re asking about is to indicate degrees of enlargement. 2x, 3x… 10x (them an image projected of 24x36cm). It must be linked with the head of enlarger. When you change the position of it the piece will show the new enlargement rate. Yes, as maxspbr says, this is an illuminated scale giving indications of the enlargement. It should switch on when you switch on the enlarger, either to set the negative and the size, or when you expose. You have an early Ic with this scale on the baseboard. There should be a cloth ribbon wound around the round part on the right of the scale which should be attached to a clip hanging from the parallelogram. This system is often broken or missing, but don't worry as you can well do without it. The later Focomats have the scale, when present, directly attached to the parallelogram. I never use it, but I like it as an orientation point when I expose. My darkroom lights switch off when exposing and this dim light helps me see in the dark. It needs socalled signal bulbs. I know many people who print with the Ic or the IIc, not many use this indicator.    Link to post Share on other sites More sharing options...
ChrisP08 Posted December 30, 2023 Author Share #4 Â Posted December 30, 2023 Thank you both for answering my question! Happy New Year. 1 Link to post Share on other sites More sharing options...
