Hi,
I am doing a lot of remote stuff with my cameras.
So I am stuck with doing the exposure from far away up to 300 meter.
Annone experienced in how you can do a remote set up for the SL2-s system?
I checked the Leica Fotos app but this is not very helpful.
I would love to know if someone on this forum got this going.
cheers Peter
  • jaapv changed the title to Wireless control / Remote / raspberry Pi
4 hours ago, Pelu2010 said:
Hi,
cheers Peter
Pocket Wizard should trigger your SL2-S on a distance up to 500 m (based on my memory; I have used it up to 100+ m without problem). I also use MIPOS, but I dont think this trigger works on 100+ m distance.
For 'all' remote triggers to be used on SLx and S (006/3), go for the Panasonic plug. In addition you typically need an adapter from the Panasonic plug to Leica.
Pass a word with the solution working for you; but I can at least confirm that Pocket Wizard and MIOPS (and several other remote shutters) work on SLx - with 'correct' adapter between the Panasonic plug and that used by Leica.
Edited by helged
Hey ,
thanxs . It just gave me an idea!
I have some godox trigger and I think they can be switched from trigger to remote. So I will check this.
thanxs for the other tips!
cheers peter
