EXIF Data Incorrect
photolandscape
I have a 90mm Elmarit, and a 28 Elmarit. Both are coded. When I review the EXIF data for my shots, the lens used is correct, the ISO setting is correct, and so is the shutter speed--but the f/stop is always recorded as 2.8. Is there a way to correct this, and what may be causing it--I'd like to get the correct information recorded in my data. Thanks.
The only aperture data in M8 DNGs EXIF data is the maximum f-stop, which is what I think you're looking at - that would be correct at 2.8 for both those lenses, so what's in the EXIF is not incorrect.
Actual aperture is only available as an estimate, and is encoded into the MakerNotes. Right now, there's no publicly available way to read that data. But watch this space..........that should change soon.
Sandy
Steve: there was speculation that the light sensor (blue dot) on the front of the camera measures ambient light and the camera can compare that to the actual brightness coming through the lens and make a fair guess as to the aperture used. A guess close enough to adjust the vignetting correction for wide lenses, but (so I understand) only within 1.5 f/stops or so, which Leica decided was too inaccurate to record in the EXIF.
People would take two exposures at, say, f/4, and get EXIF data that showed one was taken at f/2.5 and the other at f/4.5, and be sure something was "wrong" with the camera.
I played with a beta M8 a year ago, with (I think) 0.9 firmware, and it DID record the shooting aperture as well as the max. aperture (in jpegs, not RAW) even with uncoded lenses - and it was rather variable from shot to shot, as Leica expected.
Apparently they deleted the functionality in the production versions.
