My M11 no longer charges the battery from USB (directly from the camera).
From the menu the item is active. By connecting it to charging, the orange light turns on for a few seconds, but then goes off and does not charge.
I used the original cable! Instead it works normally with the charging accessory
Is this normal?
Is the camera really not charging or is it just the green ground LED not flashing to indicate charging? Just leave the camera plugged in for a while and see what happens. Or turn it on and off briefly once when you have connected it. Then the green LED should flash. At the moment there is still a bug here, but it will be fixed soon.
I did all the tests you suggested. The orange LED always lights up, but goes off after about 7 seconds. Now I have a charged battery, when it is empty I will leave it charging even if the LED goes off. I'm starting to think it's a bug !!
18 minutes ago, elmars said:
The orange LED is meaningless. A green LED in the bottom of the camera is important. It indicates whether charging is in progress. Then it flashes.
I'm screwed 😮‍💨
The protective leather caseback did not allow me to see the green LED under the camera!
Once charged, it stays on.
I thought the orange LED was important.
I will try the recharge when it runs out
Thank you very much Elmars 😃
  • Haha 1
14 minutes ago, Terin said:
I'm screwed 😮‍💨
Another clever piece of engineering in the case to hide the light! Wow do these people test these things before the production begins or are a we all beta testers.
