Vario-Elmarit, Lumix FZ20, USA to Istanbul, Can Charger work on 220 Volts ?
I found that at panasonic forum :
I have the FZ-10 and it's charger which was rated 100-240 volts, 50/60 cycles. I took it to Germany and just added a proper slip-on plug and it worked fine.
Just add the proper plug for the area you are visiting and you'll be fine.
JNS05 wrote:
Hi
Has anyone used the charger that comes with the FZ20 with 220v.
Other than needing a plug adapter, are there any problems?
Is the time needed to charge different? Is it as easy to use as in
the US?
Thanks
