Summarit Codes
sean_reid
x
Carsten is showing the codes on his link but no images, so I'm sure he would appreciate images of the codes plus of course, it will be interesting to know if the codes for the new lenses (especially the 35) are a useful alternative for "non-codeable by Leica" lenses.
The 6 bit code allows codes in the range 0 - 63. Leica reserved code 0 for "uncoded", the range 1 - 23 for old lenses and the range 24 - 63 for current (at the time the M8 was introduced, at least 2 of which, probably 4 have now gone) and future lenses.
The new Summarits take them up to 46 which leaves them 17 codes to use for future lenses. If they do run out of codes, they would need to start using combinations of code and pre-view lever position.
I know but I've never quite seen the point.
The pictures are there to give people a quick "visual orientation" to each specific code so that one doesn't accidentally code a lens backwards. I find it useful when I'm coding lenses and have twenty other things on my mind.
Cheers,
Sean
