Yesterday, I was out taking pictures, and the manual focus ring felt like it had more resistance than usual when turning it. I had used it a day or two before, and everything felt fine. The only thing I noticed that was different was that the lens was a bit warm from the sun hitting it. Before putting it away, I moved the focus ring back and forth several times to see if it would loosen things up, the camera is cool now and seems to be back to normal.
Should I be concerned or is this normal?
x
