Denebola Posted August 5, 2023 Share #1 Posted August 5, 2023 Advertisement (gone after registration) We all know how much good is the Summilux lens provided with the Leica Qn. Even if it's fantastic at any aperture, for sure there will be one which will be even better ("sweet spot"). Based on technical information as well as your esperience, what is the "sweet spot" aperture of this lens? Link to post Share on other sites More sharing options...
Advertisement Posted August 5, 2023 Posted August 5, 2023 Hi Denebola, Take a look here Leica Qn aperture sweet spot? . I'm sure you'll find what you were looking for!
hedleyw Posted August 5, 2023 Share #2 Posted August 5, 2023 For me the aperture choice is more determined by my DOF choice than for image quality per se. In terms of softening coming in due to diffraction, that is pixel size dependent so I tend to limit myself to f8 at the top end for my Q3, whereas for the Q I would be happy at f11. 2 Link to post Share on other sites More sharing options...
Qwertynm Posted August 5, 2023 Share #3 Posted August 5, 2023 Whatever f stop the scene requires. What do you want to know exactly? The lens in the Q1-3 is good in the centre from f/1.7. The edges get better beyond f/5.6. Diffraction sets in about f/6.3. above that it’s a tradeoff between DoF and loss of resolution due to diffraction. If you need tack sharp front to back I‘d suggest to focus stack the scene and use f/4 or f/2.8 as that’s probably where the lens has the most resolution. Link to post Share on other sites More sharing options...
Denebola Posted August 5, 2023 Author Share #4 Posted August 5, 2023 These answers were exactly what I was searching for. Of course the aperture can be different following the picture needs, but some indication like the one you both wrote are good guidelines in case I could choose a value or another. Thanks! Den 1 Link to post Share on other sites More sharing options...
