x
Edited by menbow
On 7/26/2023 at 8:28 PM, mihklI said:
I got one (original Leica black) and the rigid bottom plate damaged the camera :(
I read this post while away from my brand new Q3 that I just installed the black leather Leica case (19651). I came home, removed the case and sure enough, it caused wear to my brand new Q3. Removed a tiny bit of black paint from the base near the LCD screen (below the USB-C door). I just received the case brand new from Popflash. I’ll be returning it with a note to return to Leica as defective.
After reading about this on another post, I inspected mine when it arrived and sure enough there were very sharp top edges on the bottom composite plate that could cause scratching...I took some fine emery cloth and gently rounded the inside top edges of the bottom plate before installing on the Q3 and problem solved.
