AZN Posted July 31, 2023 Share #41 Â Posted July 31, 2023 Advertisement (gone after registration) > 1000s of shots per session Why not use a USB-C battery bank? Â You can get these in 20AH capacity. Â A couple of them should be enough. Link to post Share on other sites More sharing options...
Advertisement Posted July 31, 2023 Posted July 31, 2023 Hi AZN, Take a look here What I feel upset with SL-2. I'm sure you'll find what you were looking for!
Paco Rosso Posted August 1, 2023 Author Share #42  Posted August 1, 2023 On 7/30/2023 at 9:05 PM, Olaf_ZG said: That is not photography, it’s a movie…. jajajjajajajaja. No, no. This is in three weeks, not one single session.  On 7/30/2023 at 9:05 PM, Olaf_ZG said: That is not photography, it’s a movie….  Link to post Share on other sites More sharing options...
Paco Rosso Posted August 1, 2023 Author Share #43 Â Posted August 1, 2023 On 7/31/2023 at 10:50 AM, Simone_DF said: Imagine culling 2000 shots each session, what a nightmare! The story of my life last 9 years. (Cats bless lightroom). Â Link to post Share on other sites More sharing options...
LocalHero1953 Posted August 1, 2023 Share #44  Posted August 1, 2023 (edited) On 7/28/2023 at 11:21 PM, Jean-Michel said: Just to see for myself about the delay in seeing/taking for the SL2. I photographed an online timer. I pressed the shutter button as close I could do when the timer hand was in the centre of the interval. In all cases there is a tiny bit of delay — the small numbers show the fractional difference. The delay is there, but it is really tiny, and may well simply be caused by my finger pressure delay. I repeated the test a couple of times and in all cases there was a similar result. I my type of photography, including occasional casual and formal portraiture, this is really an non-issue. The exposure time was 1/250 of a second. The delays noted are less than 1/250 of a second. The seconds hand, in each case, moved 1/250 of a second between the start and end of the exposure, so really, can we even consider the delay a real delay given the length of the exposure!? I tried to upload 14 small jpgs ( all below the max file size) with an error message. So I will try to upload then a little later.  I find the EVF lag increases in low light - I agree that in good light the EVF lag is not a problem, but it certainly can be as light levels drop. It was one of the things I have always evaluated before buying the TL2 (poor), CL (better), SL (quite good) and SL2-S (fairly good)*. The EVF for the M240 and M10 was terrible. Too many people ask for a higher resolution EVF, when a more useful one would be more responsive, especially in low light.  *Measured on the LocalHero1953 scale. Edited August 1, 2023 by LocalHero1953 1 Link to post Share on other sites More sharing options...
Photoworks Posted August 2, 2023 Share #45 Â Posted August 2, 2023 5 hours ago, LocalHero1953 said: I find the EVF lag increases in low light - I agree that in good light the EVF lag is not a problem, but it certainly can be as light levels drop. It was one of the things I have always evaluated before buying the TL2 (poor), CL (better), SL (quite good) and SL2-S (fairly good)*. The EVF for the M240 and M10 was terrible. Too many people ask for a higher resolution EVF, when a more useful one would be more responsive, especially in low light. Â *Measured on the LocalHero1953 scale. I agree with you that many cameras a challenged by low light. Â I feel the M11 has the same challenge on EVF in low light, but especially when the stage color is blue. I have used all the latest some cameras in this situation too and the OLED-EVF gets real grani and low res. Link to post Share on other sites More sharing options...
