fursan Posted November 10, 2007 Share #1 Posted November 10, 2007 Advertisement (gone after registration) the first 2 rolls are back from the shop. the results couldn't be worse. i really messed up but don't know how or where. the first is a sample with tmax 400 and 2nd is tmax 100. no exposure manipulations. pointed to gray and what the meter said i obeyed. what have i done wrong? and any suggestions are gratefully awaited. tmax 400: tmax 100: Thank you folks. Link to post Share on other sites More sharing options...
Advertisement Posted November 10, 2007 Posted November 10, 2007 Hi fursan, Take a look here need help, please. I'm sure you'll find what you were looking for!
cocker Posted November 10, 2007 Share #2 Posted November 10, 2007 What did the "shop" do by way of processing? - develop -Scan - print etc. They are very grainy - much more than I would expect with that film and a bit of work can punch the flatness of them up. There quite a lot of "crud" on them as well. I suspect its poor processing rather than your metering that's to blame. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/37768-need-help-please/?do=findComment&comment=399131'>More sharing options...
fursan Posted November 10, 2007 Author Share #3 Posted November 10, 2007 Thanks Keith for taking the time to view and respond. The shop just developed it. I scanned it at another shop. what is ' crud ' ?. Such grain ? Regards. What did the "shop" do by way of processing? - develop -Scan - print etc. They are very grainy - much more than I would expect with that film and a bit of work can punch the flatness of them up. There quite a lot of "crud" on them as well. I suspect its poor processing rather than your metering that's to blame. Link to post Share on other sites More sharing options...
pemayeux Posted November 10, 2007 Share #4 Posted November 10, 2007 I agree, looks like shoddy processing. I would try some Ilford XP2 Chromogenic exposed at asa 200 and see how your metering looks. That film would be easier to have processed. Link to post Share on other sites More sharing options...
rubenkok Posted November 10, 2007 Share #5 Posted November 10, 2007 It IS poor processing. Old devolper is used. I once have had the same problem. Use a b&w film for C-41 processing like Paul is mentioning. Kodak Professional BW400CN Film or Ilford XP2 Super to check your metering. Processing is far more constant. Excellent film material and even better to scan. Ruben Link to post Share on other sites More sharing options...
fursan Posted November 10, 2007 Author Share #6 Posted November 10, 2007 Thanks for looking Paul. have to get xp2 from dubai. not available here and neither is bw400cn. Thanks. I agree, looks like shoddy processing. I would try some Ilford XP2 Chromogenic exposed at asa 200 and see how your metering looks. That film would be easier to have processed. Link to post Share on other sites More sharing options...
fursan Posted November 10, 2007 Author Share #7 Posted November 10, 2007 Advertisement (gone after registration) Ruben, thanks for your advice. the films you mention are not available here. I shall order them from dubai. i shall have a talk with the shop owner tomorrow. at least he should know. Regards. It IS poor processing. Old devolper is used. I once have had the same problem. Use a b&w film for C-41 processing like Paul is mentioning. Kodak Professional BW400CN Film or Ilford XP2 Super to check your metering. Processing is far more constant. Excellent film material and even better to scan. Ruben Link to post Share on other sites More sharing options...
stunsworth Posted November 10, 2007 Share #8 Posted November 10, 2007 The photographs you've posted are all relatively light in terms of exposure. Is it possible that you used the in camera setting for the metering and they are underexposed? After saying that, the grain is far worse than I would expect from T-Max 100/400. Were the scans made by the lab? Dis they have ICE - or the equivalent - switched on? Do you know what developer was used? Link to post Share on other sites More sharing options...
xjr Posted November 11, 2007 Share #9 Posted November 11, 2007 Were these films fixed properly ? Some years back I had something similar if not quite the same, sent results to ilford and the answer was wrong fixation ! re-checking my own labelled fixer bottles I realise that the solution was 1:9 as opposed to 1:4 required.Just re-fix them...it would not do any harm I suppose. Link to post Share on other sites More sharing options...
rubenkok Posted November 11, 2007 Share #10 Posted November 11, 2007 I tried to correct them in LightRoom, not much improvement Ruben Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/37768-need-help-please/?do=findComment&comment=399412'>More sharing options...
abrewer Posted November 11, 2007 Share #11 Posted November 11, 2007 What did the "shop" do by way of processing? - develop -Scan - print etc. They are very grainy - much more than I would expect with that film and a bit of work can punch the flatness of them up. There quite a lot of "crud" on them as well. I suspect its poor processing rather than your metering that's to blame. Agree with Keith. There does seem to be an awful lot of graininess, more than normal; but I'm not too concerned about your initial exposure, as it looks pretty reasonable from here. Recall that scanning flattens the dynamic range somewhat and you need to bring some "punch" back with Photoshop (or Lightroom, or whatever). If you don't know how to use "Levels" to do that give a shout and I'll walk you through it here. Keep shooting! Thanks. Allan Link to post Share on other sites More sharing options...
fursan Posted November 11, 2007 Author Share #12 Posted November 11, 2007 Steve thanks. but don't understand...if pics are light in terms of exposure, have i not over exposed. yes i used the camera in meter setting. I do not know what developer the shop used. The photographs you've posted are all relatively light in terms of exposure. Is it possible that you used the in camera setting for the metering and they are underexposed? After saying that, the grain is far worse than I would expect from T-Max 100/400. Were the scans made by the lab? Dis they have ICE - or the equivalent - switched on? Do you know what developer was used? Link to post Share on other sites More sharing options...
fursan Posted November 11, 2007 Author Share #13 Posted November 11, 2007 Sorry Angelos, do not know what chemicals the shop used. i shall try another shop the next time and see. Regards. Were these films fixed properly ?Some years back I had something similar if not quite the same, sent results to ilford and the answer was wrong fixation ! re-checking my own labelled fixer bottles I realise that the solution was 1:9 as opposed to 1:4 required.Just re-fix them...it would not do any harm I suppose. Link to post Share on other sites More sharing options...
fursan Posted November 11, 2007 Author Share #14 Posted November 11, 2007 Appreciate your help Ruben. I tried to correct them in LightRoom, not much improvementRuben Link to post Share on other sites More sharing options...
fursan Posted November 11, 2007 Author Share #15 Posted November 11, 2007 Allan, thanks a bunch. I am pretty proficient with ps. i am just worried that i might be doing something terribly wrong with the metering or exposure. Best. Agree with Keith. There does seem to be an awful lot of graininess, more than normal; but I'm not too concerned about your initial exposure, as it looks pretty reasonable from here. Recall that scanning flattens the dynamic range somewhat and you need to bring some "punch" back with Photoshop (or Lightroom, or whatever). If you don't know how to use "Levels" to do that give a shout and I'll walk you through it here. Keep shooting! Thanks. Allan Link to post Share on other sites More sharing options...
rubenkok Posted November 26, 2007 Share #16 Posted November 26, 2007 Fahim, Could you find/buy the film material ? Do you have better results already ? I'm just curious All the best, Ruben Link to post Share on other sites More sharing options...
fursan Posted November 27, 2007 Author Share #17 Posted November 27, 2007 Ruben, i was unable to find the film or the material you suggested. am in canada now and am taking a lot of different films to try back home. Thanks for asking. Fahim,Could you find/buy the film material ? Do you have better results already ? I'm just curious All the best, Ruben Link to post Share on other sites More sharing options...
thomasw_ Posted November 27, 2007 Share #18 Posted November 27, 2007 Hi Fursan, I think that you would benefit hugely from developing your own negatives. Perhaps instead of wet printing, you could scan them with a decent scanner like an Epson V700 for the purposes of sharing your images on the Web. Developing B+W film is quite straightforward; you just need a changing bag, a developing tank, thermometer, developer, stop bath and fixer. Most of the mixing containers can be purchased at "dollar" stores for very little. It is quite fun and you get the control over the developing and scanning. Regards, Thomas Link to post Share on other sites More sharing options...
rob_x2004 Posted November 27, 2007 Share #19 Posted November 27, 2007 Just out of interest, what are you using Thomas? Link to post Share on other sites More sharing options...
boilerdoc Posted November 27, 2007 Share #20 Posted November 27, 2007 Looks like they were processed in Rodinal! You have to visually look at the negatives to assess the density to know if they are properly exposed and processed. I'd not trust anyone to do my silver halide films but the chromogenics (T400B&W or XP2 Super) the labs can handle very well. They are color negative film after all. Steve Link to post Share on other sites More sharing options...
