On 5/22/2023 at 4:51 PM, maidenfan84 said:
Wondering if anyone has any experience with this bag and an SL2s? I’m looking at getting the sl2s w/50mm sl combination, not sure it will fit in my bag or if I’d need to consider getting another one? Thank you, in advance
I don't think so; I have the PD 6L and I can barely fit the SL2 with the 24-70 lens. A smaller lens won't help; the issue is that the body is so tall that the zipper barely closes. I can't imagine that the 3L will be big enough.
On the PD site, it shows the internal dimensions of the 6L at 11cm near the top then tapers down to 9cm at the bottom, and the SL2(s) is 10.7cm tall; so as mentioned it barely fits.
The 3L shows the internal dimensions as 10cm top and 8cm, so I can't see how you could close the zipper.
OR, you take the lens off the camera and store them separately, side by side. That would be a deal breaker for me.
Again this is not due to the size of the lens, but the height of the body.
Brad
Hi I own the Everyday Sling 5L (V1) and the SL2S barely fits with a 20-60 Panasonic. The zipper w closes by it is very tight.   The top of the SL2S sticks out a lot to that makes it tight on my sling.  The 3L is  slimmer than that 5L so it will likely not fit.
  • 3 months later...
I hesitated for a long time, but I bought a bag (3L, 6 is good for SL). I think you can't use this bag with SL2 + big lens. maximum lens size comparable to panasonic 24-105.
Sl2s + 24-105 + hood – i can't close bag. I installed the hood so that the size is comparable to elmarit 24-90
SL2 + 24-105 without hood – ok
I'm used to carry my Sl2-S + VE 24/90 in my small Ona Bowery Bag. There is room for the hood as well and there is the side pocket for the spare battery.
