Cpierce9515 Posted March 28, 2023 Share #1 Posted March 28, 2023 Advertisement (gone after registration) Hello, picked up this lens and body with a kit as my first bit of Leica gear and wanted to know why there is no serial number and why it’s gold/bronze tinted. Did a bit of googling and all I could really find was that it maybe came with an enlarging set? I’ve also seen the term “snail cam” what exactly is that. thank you Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/374714-leitz-elmar-35cm-135-no-serial-number/?do=findComment&comment=4738146'>More sharing options...
Advertisement Posted March 28, 2023 Posted March 28, 2023 Hi Cpierce9515, Take a look here Leitz Elmar 3.5cm 1:3.5 no serial number . I'm sure you'll find what you were looking for!
willeica Posted March 28, 2023 Share #2 Posted March 28, 2023 'Snail cam' or 'heavy cam' for the piece that operates the rangefinder. Prior to late 1931 Leica lenses did not have serial numbers. I have a heavy cam 3.5cm Elmar from 1932 , but it has a serial number. Prior to that, lenses only carried numbers (usually last 3 digits of the camera number) if they were being matched with a I Model C Non Standardised camera. The snail/heavy cam lenses with no serial numbers either had a cam in anticipation of cameras with rangefinders being produced or had the cam added later. The yellow is from the ageing nickel on the lens. I hope that all of this is not too confusing. The period from 1930 to 1933 was one of immense and rapid change in Leitz/Leica product features. William 1 Link to post Share on other sites More sharing options...
Cpierce9515 Posted March 28, 2023 Author Share #3 Posted March 28, 2023 22 minutes ago, willeica said: 'Snail cam' or 'heavy cam' for the piece that operates the rangefinder. Prior to late 1931 Leica lenses did not have serial numbers. I have a heavy cam 3.5cm Elmar from 1932 , but it has a serial number. Prior to that, lenses only carried numbers (usually last 3 digits of the camera number) if they were being matched with a I Model C Non Standardised camera. The snail/heavy cam lenses with no serial numbers either had a cam in anticipation of cameras with rangefinders being produced or had the cam added later. The yellow is from the ageing nickel on the lens. I hope that all of this is not too confusing. The period from 1930 to 1933 was one of immense and rapid change in Leitz/Leica product features. William Thank you, that’s a perfect explanation. Link to post Share on other sites More sharing options...
jc_braconi Posted March 28, 2023 Share #4 Posted March 28, 2023 Usually this eleven o'clock lens was for use on camera with no slow speed selector like Leica standard or Leica C and Leica II. Link to post Share on other sites More sharing options...
Cpierce9515 Posted March 28, 2023 Author Share #5 Posted March 28, 2023 (edited) 4 hours ago, jc_braconi said: Usually this eleven o'clock lens was for use on camera with no slow speed selector like Leica standard or Leica C and Leica II. I have noticed that it does very slightly clip the slow speed dial when it moves past it Edited March 28, 2023 by Cpierce9515 Link to post Share on other sites More sharing options...
