Casey Jefferson Posted March 28, 2023 Share #1 Posted March 28, 2023 Advertisement (gone after registration) OK, another paranoia, bear with me 😂 Hope anyone can do a quick check if the aperture ring has slight play/wiggle side way (in any of the detent)? I was trying to move the aperture to A just to check the function and it required quite some force, then when it finally click into it, and back to 1.7, I start to notice the wiggle that I haven't notice before. It's probably there all the time 😂 I'm not worried if it's an M lens as it's mechanical and can be services but not sure if it's a sign of any sort on by wire lens, so just thought of doing a quick check with you guys and hope to get some responses 🙏🏻 Link to post Share on other sites More sharing options...
Advertisement Posted March 28, 2023 Posted March 28, 2023 Hi Casey Jefferson, Take a look here Q2 aperture ring slight play . I'm sure you'll find what you were looking for!
bobtodrick Posted March 28, 2023 Share #2 Posted March 28, 2023 I think it is just excess worry. The lens goes into A easily...but takes more force to get it out of A...this I probably meant to be so that people who like to leave a lens on auto don't move it off of A accidentally. And there is a minute amount of play...as you say it is a mechanical interface. 1 Link to post Share on other sites More sharing options...
Casey Jefferson Posted March 28, 2023 Author Share #3 Posted March 28, 2023 (edited) 8 hours ago, bobtodrick said: I think it is just excess worry. The lens goes into A easily...but takes more force to get it out of A...this I probably meant to be so that people who like to leave a lens on auto don't move it off of A accidentally. And there is a minute amount of play...as you say it is a mechanical interface. On mine it take as much force to go into A mode as going out. I bought it used but it didn't really get much use by the previous owner. It probably never enter the A mode prior to that... But thanks for the report, I've read quite some reports of Q aperture ring acting up and not reporting correct aperture value, hence the paranoia... Edited March 28, 2023 by Casey Jefferson Link to post Share on other sites More sharing options...
Pavel Lozinsky Posted July 15, 2023 Share #4 Posted July 15, 2023 I have the same situation. There is a slight play in the aperture ring 😢 Link to post Share on other sites More sharing options...
