This is after Topaz.
21 hours ago, High_n_Dry said:
You are right. Does this occur mainly in the 246? I don't see this with lens correction on with the M11.
If you process the file directly via LR, it will process and output as a DNG
Lens correction banding occurs on any camera when iso is high enough to make noise create a pattern.
I tried topaz with an rgb DNG converted file... it doesn't really work for my needs.
Unless there are alternatives, I think I'll have to live with banding...
Edit: do you mind sharing your process on topaz? It seems you squeezed out of it more than I can.
Edited by Besprosvet
Ahh, thanks for the explanation.
As you know, Topaz has a multiple programs. This is with Topaz AI, their all in one package. For this photo, I just hit the correct button with no other tweaking.
