paulhillion Posted February 17, 2023 Share #1 Posted February 17, 2023 (edited) Advertisement (gone after registration) I've just bought the Q2 to go alongside my Q2M. Switching on the Q2 for the first time I could hear what I assume to be the OIS motor? whirring faintly away in the background, it seems to be almost continuous (even with OIS turned off) only stopping when I focus. The Q2M is silent compared to the Q2 and I'm wondering if this is normal with the Q2 or I have a faulty camera? Thanks. Edited February 17, 2023 by paulhillion Link to post Share on other sites More sharing options...
Advertisement Posted February 17, 2023 Posted February 17, 2023 Hi paulhillion, Take a look here OIS? whirring noise on Q2 compared to the silent Q2M . I'm sure you'll find what you were looking for!
Tomas Eriksson Posted February 17, 2023 Share #2 Posted February 17, 2023 Same with my Q2 (and Q...) so perfectly normal. It's part of the lens design. When the camera is on there is a current keeping the lenses floating in the correct position. So meaning, even with OIS disabled it will still be turned on but it won't do any active stabilisation. If it wasn't turned on the lens would be clunking like it does when the camera is turned off. Link to post Share on other sites More sharing options...
paulhillion Posted February 17, 2023 Author Share #3 Posted February 17, 2023 1 hour ago, Tomas Eriksson said: Same with my Q2 (and Q...) so perfectly normal. It's part of the lens design. When the camera is on there is a current keeping the lenses floating in the correct position. So meaning, even with OIS disabled it will still be turned on but it won't do any active stabilisation. If it wasn't turned on the lens would be clunking like it does when the camera is turned off. Thanks Tomas, that's reassuring to know. I guess Leica changed or improved the design with the Q2M. 1 Link to post Share on other sites More sharing options...
BrettWayne Posted February 18, 2023 Share #4 Posted February 18, 2023 23 hours ago, paulhillion said: I've just bought the Q2 to go alongside my Q2M. Switching on the Q2 for the first time I could hear what I assume to be the OIS motor? whirring faintly away in the background, it seems to be almost continuous (even with OIS turned off) only stopping when I focus. The Q2M is silent compared to the Q2 and I'm wondering if this is normal with the Q2 or I have a faulty camera? Thanks. It’s the mixer stirring up the colors for you. 2 4 Link to post Share on other sites More sharing options...
Driften Posted February 19, 2023 Share #5 Posted February 19, 2023 I've never noticed a noise like that from my Q2... and I would think the Q2M would act and sound the same. If both the Q2 and Q2M have the same settings I would think they would sound the same. I don't see the Q2 having predictive focus that tries to guess what you want before half press. I normally shoot afs not afc so is that it? I keep OIS on auto, you might double check that is the same between the two. Link to post Share on other sites More sharing options...
Tomas Eriksson Posted February 20, 2023 Share #6 Posted February 20, 2023 16 hours ago, Driften said: I've never noticed a noise like that from my Q2... and I would think the Q2M would act and sound the same. If both the Q2 and Q2M have the same settings I would think they would sound the same. I don't see the Q2 having predictive focus that tries to guess what you want before half press. I normally shoot afs not afc so is that it? I keep OIS on auto, you might double check that is the same between the two. Haven't held a Q2M but Im assuming it also has floating lens elements. When it's turned of and you shake it, does the lens make clunking noises like normal Q/Q2s? Link to post Share on other sites More sharing options...
paulhillion Posted February 20, 2023 Author Share #7 Posted February 20, 2023 Advertisement (gone after registration) 1 hour ago, Tomas Eriksson said: Haven't held a Q2M but Im assuming it also has floating lens elements. When it's turned of and you shake it, does the lens make clunking noises like normal Q/Q2s? Hi Tomas Yeah it does, exactly the same. I've listened again to my Q2M and there is indeed the same whirring noise as on the Q2 but it is noticeably softer (smoother if that makes sense), which is probably why I've not noticed it until I turned on the Q2 for the first time. Anyway, time to stop listening to it and get out there and start using it 🙂 Link to post Share on other sites More sharing options...
Tomas Eriksson Posted February 21, 2023 Share #8 Posted February 21, 2023 20 hours ago, paulhillion said: Hi Tomas Yeah it does, exactly the same. I've listened again to my Q2M and there is indeed the same whirring noise as on the Q2 but it is noticeably softer (smoother if that makes sense), which is probably why I've not noticed it until I turned on the Q2 for the first time. Anyway, time to stop listening to it and get out there and start using it 🙂 Thank you for confirming. Yes agree! Let's spend more time taking amazing photos. Link to post Share on other sites More sharing options...
