Lightroom Export DNG
asfeir
I noticed that if one exports M8 files in lightroom using export to dng lossless compression, one gets files that are about 5 to 6 MB down from 10.
Any information on how this can be? are we losing anything in this operation? If not, it is worthwhile doing it to save disk space
x
You don't lose any pixel data - lossless DNG compression is just Huffman coding (Huffman coding) - Wikipedia, the free encyclopedia. It just takes advantage of the fact that very often, a pixel has a similar value to the one next to it, so you can save space by just storing the difference between values.
What you may see is some changes to metadata - Adobe tends to add their own - and you will probably lose the Leica MakerNotes, as they are tagged by Leica as "unsafe", and so should not be copied forward. However, that will happen regardless of whether you use lossless compression or not.
Sandy
Sandy
I know what Huffman coding is, but could not find any reference to the type of compression. Thanks for pointing this out. This compression is very helpful to reduce the file size.
I checked the metadata that is displayed in Lightroom. No changes take place there. Where can you see the Leica MakerNotes?
