Zeiss 18mm f/4 Distagon ZM - Questions
atufte
Anyone know if the fact that the 18 ZM brings up the wrong framelines also interact with the RF/focus, mine is focusing fine, but the RF seem to "hang" or not be right, but with a measuring band i tested it from it's shortest 0.5m to 5m and infinity, and it seems spot on... would it help when i get the 28/90 mount...? which is off to JM for milling.
Thanks in advance...
x
Alexander, I think you are talking about close focussing - if so, the thing is that the RF mechanism is coupled until 0.7m, after that the RF disengages and therefore stops moving but, of course, the lens' focusing cam doesn't and focusses as close as it is built for. Hope this helps :D
Thanks Vieri, that's probably it, it stops in the finder but shows up right with a measuring band...and i thought something was seriously wrong, that's was a great relief, thank you again... :-)
