Farrell Gallery Posted February 5, 2023 Share #1 Posted February 5, 2023 Advertisement (gone after registration) The other night I did some 60 second exposures with the Q2, and anything longer than that is T mode. Am I correct that in T, once I press the shutter button, it keeps recording until I press it again and then does long exposure noise reduction? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! 3 Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/365274-t-shutter-speed-mode/?do=findComment&comment=4673029'>More sharing options...
Advertisement Posted February 5, 2023 Posted February 5, 2023 Hi Farrell Gallery, Take a look here T shutter speed mode. I'm sure you'll find what you were looking for!
Farrell Gallery Posted February 8, 2023 Author Share #2 Posted February 8, 2023 Update- my assumption was right according to Brian at Leica. A convenient alternative to bulb mode. 1 Link to post Share on other sites More sharing options...
BrettWayne Posted February 10, 2023 Share #3 Posted February 10, 2023 On 2/9/2023 at 3:44 AM, Farrell Gallery said: Update- my assumption was right according to Brian at Leica. A convenient alternative to bulb mode. Are you able to do this in the app remotely? Link to post Share on other sites More sharing options...
Farrell Gallery Posted February 10, 2023 Author Share #4 Posted February 10, 2023 58 minutes ago, BrettWayne said: Are you able to do this in the app remotely? Most likely so, never used the app. But for that kind of exposure time, it may be worth trying...assuming there's a signal where i shoot. 1 Link to post Share on other sites More sharing options...
Anakronox Posted February 10, 2023 Share #5 Posted February 10, 2023 It’s Bluetooth and Wi-Fi only, so you’ll need to be fairly close to trigger the camera 😁 1 Link to post Share on other sites More sharing options...
Farrell Gallery Posted February 10, 2023 Author Share #6 Posted February 10, 2023 1 hour ago, Anakronox said: It’s Bluetooth and Wi-Fi only, so you’ll need to be fairly close to trigger the camera 😁 With the price of a Leica, I’m never far from it, lol, 1 Link to post Share on other sites More sharing options...
ianforber Posted February 11, 2023 Share #7 Posted February 11, 2023 Advertisement (gone after registration) Worth checking whether you have the latest firmware. When I first used the app to trigger the Q2, I got caught out because the camera switched to AF even though I had manually focused on something (ie without me switching the lens back to AF). I think this was updated in the most recent firmware update but haven’t used the app recently with the Q2 so can’t confirm. Link to post Share on other sites More sharing options...
Farrell Gallery Posted February 11, 2023 Author Share #8 Posted February 11, 2023 (edited) 3 hours ago, ianforber said: Worth checking whether you have the latest firmware. When I first used the app to trigger the Q2, I got caught out because the camera switched to AF even though I had manually focused on something (ie without me switching the lens back to AF). I think this was updated in the most recent firmware update but haven’t used the app recently with the Q2 so can’t confirm. I like 4.0, when I first got my Q2 used (had 3.0) I couldn't stop the swipe across the screen changing to video....now with EVF extended, it can't do that. Edited February 11, 2023 by Farrell Gallery Link to post Share on other sites More sharing options...
tombre Posted February 23, 2023 Share #9 Posted February 23, 2023 Just to clarify that the T mode only behaves like Bulb to a certain extent. It has an overall time limit which halves as you increase ISO rating so that by (say) ISO 6400 you are limited to about 6 seconds. If you set the camera to +1 mode, then use the thumb wheel to extend the exposure time you will find the limit for that ISO rating. Now increase the ISO from say 200 to 400 and you will find the longest shutter speed is now a stop shorter than before. The T mode acts like Bulb mode as long as you don’t exceed these time limits, otherwise it just automatically truncates the exposure. Using the FotosApp does not allow you to get around this limitation. Bit frustrating when you want to do log exposure in semi-dark conditions. The Leica SL2 does not have this limitation. The math photographer YouTube channel has a good video to explain the limitation. 2 1 Link to post Share on other sites More sharing options...
