What code to use on a CV 75mm Color-Heliar?
etrigan63
x
I would recommend that you use the lens uncoded until we know the code for the 75mm Summarit. I use mine uncoded; there are no vignetting issues to worry about. I have in fact not coded any lens above 35mm (modern Leitz/Leica 90mm lenses are of course self-coding).
The old man from the Age Before Cyan Vignetting
I use mine uncoded (but with a filter) after reading Sean's review. I have been thrilled with it. You could have saved some money by getting a normal CV adapter rather than a Milich, but may you can sell it or use it on another lens.
While I realize that the code isn't really necessary for the performance of this particular lens, I do like the lens data recorded in EXIF and you never know what they might dream up in the future. And seeing that Leica is a big fan of backwards compatibility, better safe than sorry.
In that case, you'll probably settle on the 75 Rit code once we know what it is.
Cheers,
Sean
I hope what they dream up in the future is user selectable lenses in the camera menu. No more coding!
That could be an option... but.... when I see people complaining about selecting 16-18-20 for a Wate, I cannot imagine having to select the lens set-up every time.
Like many of the decisions, this is simply a marketing choice!
There is absolutely no technical reason why they couldn't do this but plenty of commercial reasons why they want to make it inconvenient to use competitors and un-coded lenses. I'm as guilty as anyone as far as breaking down and purchasing new Leica glass, even to replace some Zeiss lenses I already have that's of arguably equal or better performance. Effectively it's Leica arm-twisting customers to buy or code Leica only glass to go with their M8. Although we know here about self-coding & 3rd party milling/ring solutions from JLM and others, I'm sure that the vast majority of Leica purchasers are under the impression that only Leica glass works well with the camera. I'm certain that Leica are happy to keep it that way.
