M8 charger broke
jimbobuk
I just tried to charge my only battery today that died at the most inopportune moment today (having just taken a stream of shots in continuous mode. It sat there and finished emptying its buffers and then that was it.. no display in the battery window even, that is normal isn't it?!?).
I went and got the charger and tried it, noticed that it was quite loose as it fits in the socket (UK spec) I can't see anything in that area that has changed, i just think its part of the adapter design, and play in a normal fitted socket.
At one point i saw the light come on briefly and then off again.
You are ok plugging it in with the battery already charged aren't you?
Its not lit any LEDs since, which i guess means its broken.. I wondered about the fuse but this doesn't appear to be changeable, all being so sealed.
I then tried the DC car adapter and this lit the lights and wanted to charge the battery fine.. its obviously the AC path that requires the transformer.
Very gutting though.. any pointers? Its still in warranty so i'll be phoning Leica tomorrow.
Cheers
Jim
x
Cheers
Jim
Try popping out the plug part of the charger and re-seating it in the charger.
It just sounds very strange that you are the third person to report a broken charger in the last month or two and the second this week.
I've tried using different plug parts, including the 2 circular pins one that is what shavers have in this country, via a shaver adapter into UK 3 pin.. this didn't work either.
Can anyone else confirm that with it say switched off at the wall there is a fair amount of play in you being able to push and pull it and made it rotate more than you'd like in the vertical plane.. the kind of movement that would make fitting a battery whilst it was plugged in cause it to rotate a bit.
I just wonder if the fuse has blown somehow.
Very frustrating though.. its a 2nd hand M8 that hasn't had that much use, i've only used the charger twice now, perhaps 3 times this attempt.. other than that its been carefully sat on a shelf.
James, as Ed says, someone else has had problems with their charger too, most likely the fuse which is soldered in place.
As I've described in that thread, you can use pretty much any laptop brick (the charger is rated up to 24v - check the rating plate on the underside) to power it through the car cable.
I now use just the charger part of it, powered from the laptop brick which I always have with me.
Here the link...
http://www.l-camera-forum.com/leica-forum/leica-m8-forum/36878-non-working-m8-charger.html#post384900
The connector is not standard. You would need to cut into the cable and use a connector so that you can use one or the other. A trip to Maplin/Radio Shack might be required.
That converter is rated as 1A but the Leica charger DC input is rated as 1.1A. You may be OK though...
For what it's worth, I checked current draw some time ago at nominal 12vdc (about 13v from my small solar/wind/battery array) & starting from a not totally discharged battery the charger was drawing slightly less than 500ma, and it seemed to kind of ramp down from there as charging continued. I have yet to see what a stone-dead battery starts the charge cycle at.
I'm surprised, Mark that you haven't checked the loads while you were working on your project. I guess I have more an interest in this because I'm off grid when at the cottage and I'm mentally tallying my power useage all the time.
Robert
