Interesting software for web publishing
tbarker13
I've been toying around with a program (SoundSlide) that makes it easy to publish your photos in the form of slide shows. A lot of newspapers use the program (which is fairly cheap). Of course, you have to have your own website to do it.
Very easy to update them and make adjustments later. I've got four here that I'm working on. Just posted them this morning. I don't have the captions done. And I'll probably go without sound.
The bulk of the photos were shot either with the M8 or the R-D1. A couple canon shots as well.
Tim Barker
Tim - lovely images!
Went to look at the Soundslides site and not sure where the "sound" side of it comes and and what the point is if you don't want this side of things... Also interested to know how you feel this programme compares with slideshows generated by Lightroom or PS3... You can see examples of the HTML output (which I still prefer as it's quicker to load) at Wyzwolenie - proby or Riga - a perspective BTW - images a mix of M8 + Canon, but I thought that the forum would still allow as this issue of how we present our work is important...
Best
It is a web-based program, but you have to have your own website to use it. I would imagine that it would work with Apple also, since most newspaper photogs use Macs for their photo editing.
As I understand it, the program was designed to use an audio track that would determine how long the slide show runs for. I guess a lot of users wanted a silent option, so the newest version gives you the option of using photos only.
I haven't tried these other methods, but here is how this one works:
You open the program and tell it to start a project.
You pick a folder where your jpgs are stored and it loads them into the project.
Next, you have the option of adding a sound file.
From there you can tweak a few features (captions, image sizes, etc.)
Once you are ready to publish, you hit the "export" button. That generates a small set of files that you copy into whatever program you use to run your website - in my case, Microsoft Frontpage.
