need help-blue dots
andreas_thomsen
The bluish green dot is the internal reflection off of the UV/IR filter you have on your lens. I originally thought my m8 was defective but discovered that in low light situations with bright light sources, you'll get the dots. Remove your UV/IR and shoot the same shot and the dots will go away.
