Guest Posted February 8, 2023 Share #41 Posted February 8, 2023 Advertisement (gone after registration) 28 minutes ago, leicaoptik said: The aperture ring is not that stiff as on my other lenses. The resistance from 1.2 to 1.4 is lower compared to the other clicks. That is also the case in my new summilux 35 (FLE2) here the step from 1.4 to 1.8 Next time I am in Wetzlar I will ask Leica if that can be adjusted to a stiffer drive. The most stiff aperture ring I have in the silver chrome lenses. The smoothest has my blackpaint summilux 50mm which is butterly with just the right stop resistance Thanks! 😊 But do you have a hint of play in the rotational direction when aperture is in one of the f-stops? Link to post Share on other sites More sharing options...
Advertisement Posted February 8, 2023 Posted February 8, 2023 Hi Guest, Take a look here 50mm Summilux pre-asph E46 vs 50mm 1.2 Noctilux remake or stick with 50mm Summicron V5 . I'm sure you'll find what you were looking for!
Keith (M) Posted February 8, 2023 Share #42 Posted February 8, 2023 3 hours ago, mcpallesen said: @leicaoptik and @Keith (M), how are the aperture ring on your 50/1.2 Nocti? Well, the aperture ring relative stiffness on mine in comparison with other M lenses was a welcome surprise. Thankfully it is not anything like that of my 135mm APO Telyt-M which changes stop with the merest puff of wind! Link to post Share on other sites More sharing options...
leicaoptik Posted February 8, 2023 Share #43 Posted February 8, 2023 I do not understand exactly what you mean but the ring is not stiff in any direction, perhaps because of the high numer of blades? Link to post Share on other sites More sharing options...
Guest Posted February 8, 2023 Share #44 Posted February 8, 2023 28 minutes ago, leicaoptik said: I do not understand exactly what you mean but the ring is not stiff in any direction, perhaps because of the high numer of blades? No, not stiff. Whether it can be moved ever so slightly/wobble within the aperture click? Link to post Share on other sites More sharing options...
leicaoptik Posted February 9, 2023 Share #45 Posted February 9, 2023 My lens is stable within the aperture click, no wobble when it's locked in a position. Link to post Share on other sites More sharing options...
