90mm wide open
SnapperJ
Here is a good example of the shallow depth of field from a 90 APO/APSH wide open. The light element in focus was about 15 feet away. Take a look at the wire rope (supporting the light string) in the crop below and you can see the focus plane is very shallow. EDIT: It looks like I made the images too low resolution which is causing posterization, but they still get the point across.
I used the APO-Summicron 90mm ASPH of a friend for a while. It is a stunning lens. Super sharp wide open. I have a 75mm Summilux. It isn't as sharp at f/1.4 as the 90mm is at f/2. The Dof is the same, if you keep the same distance to the subject. The Summilux, however, allows you to work with shorter exposure time, due to the shorter focal length and wider aperture. Vibration detroys as much details as aberrations do. I prefer the Summilux 75mm bokeh. It is more creamy and soft. The 90mm's isn't bad at all, just different.
The problem with tele lenses on the M8 is focus accuracy. I am happy with my 75mm, but I am inclined to think that 50mm is the longest lens for comfortable and fast use on the M8. The low magnification of the M8's viewfinder reduces focus accuracy. You can use a x1,25 magnifier, but it affects the luminosity of the viewfinder, and the wideangles' framelines are more difficult to see. A built-in moving magnifier would be great!
Mark Thats a really nice test subject ..you can clearly see the depth of field and the accuracy of the focal point.
Thanks Roger. The light string was on a cruise ship and it was blowing around a lot in the Pacific trade winds. It took me two tries to catch it in the right position, even at 1/8000 th of a second shutter speed.
Your picture illustrates perfectly the sharpness and shallow depth of field of the 90mm lens.
I never hesitate to shoot the 90 ASP fully open: F2 + 2s self-timer makes a worthwhile IS.
The following is not exactly at 20 ft… The Areva and Cœur Defense towers are at 5 km (3 mi).
1: The usual 100% crop (after curves and a mild sharpening)
2: The full story, non-retouched
3: Different crop and different time (160 ISO, f2, 1/500, hand-held, ugly TV aerial erased).
I have been testing my 75mm Lux thinking that I had a problem with the lens or that my range finder needed alignment. As it turns out the only problem is me! The lens is sharp and the range finder is spot on, which is a relief.
I think what happened with that particular image was due to me focusing and then recomposing the image without taking this into account that the focus had shifted. I suppose at f1.4 this would be enough to produce unsharp pictures.
Anyway the photo below was taken in low light at f1.4 and is quite sharp, all be it not as sharp as the 90mm ASP.
The second photo is a small crop from the first image.
Thank you all for your helpful advice and taking the trouble to post example photos.
Just for interest :- the 75 AA cron at f2
Jeff
