techpan Posted October 1, 2007 Share #1 Posted October 1, 2007 Advertisement (gone after registration) I recently bought a 90mm Summicron ASPH APO and for portrature and decided to try some macro work to see the outcome. Below are the results. f2.0 f5.6 f16 Link to post Share on other sites More sharing options...
Advertisement Posted October 1, 2007 Posted October 1, 2007 Hi techpan, Take a look here Summicron 90mm ASPH APO for Macro Work. I'm sure you'll find what you were looking for!
TEBnewyork Posted October 1, 2007 Share #2 Posted October 1, 2007 What is interesting is the color of the fence and background in the first two shots. They almost look reversed with a dark fence and light background in the first shot and a light fence with dark green background in the second. Link to post Share on other sites More sharing options...
Hacker Posted October 1, 2007 Share #3 Posted October 1, 2007 I thought Macro generally refers to 1:1, though most people would interpret this loosely. Link to post Share on other sites More sharing options...
techpan Posted October 1, 2007 Author Share #4 Posted October 1, 2007 I thought Macro generally refers to 1:1, though most people would interpret this loosely. How big are your garden faucets? Link to post Share on other sites More sharing options...
marknorton Posted October 1, 2007 Share #5 Posted October 1, 2007 Interesting shots and I agree about the colour inversion in the BOKEH. The APO 90/2 has a maximum reproduction ratio (or minimum, depending on how you see things) of 1:9 compared to 1:3 of the 90/4 and the macro adapter. Closer work, down to 1:1 is tough without a DSLR. For that, I use a Nikon D2X and either their 60mm or 105mm VR macro, f2.8 both. Even so, shows the 90/2 is a great lens for close up work down to a field size of 220 * 330 mm, call it 9 * 13 inches for our US friends. Did you tripod mount the camera, focussing looks spot on at all apertures. My 90/2 is on its way back from coding, I've been very impressed by it, has a luminosity, a vibrancy which the 90/2.8 lacks. Link to post Share on other sites More sharing options...
techpan Posted October 1, 2007 Author Share #6 Posted October 1, 2007 Camera was tripod mounted and was set to auto release. I found the color inversion very interesting and unexpected. Link to post Share on other sites More sharing options...
jonoslack Posted October 1, 2007 Share #7 Posted October 1, 2007 Advertisement (gone after registration) Excellent Garin The 75 'cron also makes an excellent 'macro' lens going down to 1:7 ratio. Splendid for flowers and faucets! Link to post Share on other sites More sharing options...
FMB Posted October 1, 2007 Share #8 Posted October 1, 2007 Garin, have you used IR/UV filter? I've detected with this lens a better rendition of colors using the IR filter. Francisco. Link to post Share on other sites More sharing options...
Jack_Flesher Posted October 1, 2007 Share #9 Posted October 1, 2007 Be interesting to mount that lens in the macro adapter for the 90 macro and see if it worked... I suspect it might. Link to post Share on other sites More sharing options...
boilerdoc Posted October 1, 2007 Share #10 Posted October 1, 2007 Jack, it won't work with the macro adapter reportedly. It's only for use with the 90/4 Macro. The 90 Macro is a superb lens and close focusses to 1:3. And with an M8 would be ~1:2. Short of a Visoflex/bellows it can't be beat! I love my 90/2 but it isn't for really close work. For portraits tho it'll make you cry it's so good. Steve Link to post Share on other sites More sharing options...
techpan Posted October 1, 2007 Author Share #11 Posted October 1, 2007 The UV/IR filter was on but the lens is not coded. The camera was set to UV/IR and coded. I don't know if the non coded lens disables the UV/IR portion on the camera? Link to post Share on other sites More sharing options...
marknorton Posted October 1, 2007 Share #12 Posted October 1, 2007 Be interesting to mount that lens in the macro adapter for the 90 macro and see if it worked... I suspect it might. It will not work - the 90/4 has two lens cams, one for normal, one for close focussing which takes the macro adapter into account. Put the 90/2 on the macro adapter and you risk damaging it and the lens. Link to post Share on other sites More sharing options...
marknorton Posted October 1, 2007 Share #13 Posted October 1, 2007 The UV/IR filter was on but the lens is not coded. The camera was set to UV/IR and coded. I don't know if the non coded lens disables the UV/IR portion on the camera? Important not to confuse using an IR filter and coding with this lens. With wide-angles, the coding is used to correct image defects induced by the filter. With a 90mm lens, there are "none", so it makes sense to use a filter even if the lens is not coded and in this case, the camera should be set to Lens Recognition Off. The IR filter will filter out the IR induced fug which softens the image and clean up the greens and blacks but will not induce the cyan which using a coded lens and in-camera correction is designed to remove. Link to post Share on other sites More sharing options...
Jack_Flesher Posted October 1, 2007 Share #14 Posted October 1, 2007 It will not work - the 90/4 has two lens cams, one for normal, one for close focussing which takes the macro adapter into account. Put the 90/2 on the macro adapter and you risk damaging it and the lens. Okay, thanks for the clarification. Too bad though... Link to post Share on other sites More sharing options...
