howardeisemann Posted September 25, 2007 Share #1 Posted September 25, 2007 Advertisement (gone after registration) I am a bit curious if the lateral movement in the shutter speed dial is common to all M8's or peculiar to mine. Clearly, the dial on my MP is rock solid and I realize that the M8 is no MP in regard to a build quality. Perhaps I am just paramoid. Link to post Share on other sites More sharing options...
Advertisement Posted September 25, 2007 Posted September 25, 2007 Hi howardeisemann, Take a look here M8 Shutter Speed Dial. I'm sure you'll find what you were looking for!
Shootist Posted September 25, 2007 Share #2 Posted September 25, 2007 I am a bit curious if the lateral movement in the shutter speed dial is common to all M8's or peculiar to mine. Clearly, the dial on my MP is rock solid and I realize that the M8 is no MP in regard to a build quality. Perhaps I am just paramoid. I just checked both of mine and I have very slight movement. Never noticed it before because it is so slight. Link to post Share on other sites More sharing options...
howardeisemann Posted September 25, 2007 Author Share #3 Posted September 25, 2007 Thank you Ed. I guess I am somewhat relieved in that I am not facing SDDS (sudden dial death syndrome) Howard Link to post Share on other sites More sharing options...
marknorton Posted September 25, 2007 Share #4 Posted September 25, 2007 Take a look at my anatomy thread and you'll see how the dial is mounted. There is no appreciable lateral movement on any of my cameras. Link to post Share on other sites More sharing options...
Shootist Posted September 25, 2007 Share #5 Posted September 25, 2007 Take a look at my anatomy thread and you'll see how the dial is mounted. There is no appreciable lateral movement on any of my cameras. Appreciable is the key word here. I had to try moving it forward/backward & side to side before I could notice any real movement. It rotates, from the set SP, more then it moves laterally. Like I said mine barely move and it does, or seems to, move slightly more front to back then side to side If the OP's camera shows a lot of lateral movement then maybe the SP dial switch assembly need to be tightened/remounted. Link to post Share on other sites More sharing options...
