New Zeiss mount and WATE?
jamriman
I tried searching this forum and the web to find a way to get a new Zeiss flange to bring up the 28mm framelines. I have a 21mm zeiss 4.5 coded for the 21mm WATE. It codes (IR mode only) when I push the frameline lever to 28mm. Then a menu comes up with 3 WATE choices 16, 18, 21. Is this how WATE works? Anyhow, does anyone know how to get a new zeiss zm 28mm flange? Don G. and John M don't know either. Thanks
1) Yes, this is how the WATE works--instructions can be downloaded from Leica web site.
2) Your best bet would be to contact Zeiss. Lens mount can be switched relatively easily on some of their lenses, though I don't know about this one.
--HC
the detail on the mount that controls frame line selection requires that about .030" material be removed as you go from 9cm to 5cm to 13.5cm.
the Wate (9cm) requires that no material be removed.
FYI:
9cm: 90mm, 28mm, 21mm, WATE
5cm: 50mm, 75mm
13.5cm: 35mm, 24mm
.......... Anyhow, does anyone know how to get a new zeiss zm 28mm flange? ..........
You can order the ZM28 lens mount from Zeiss in Germany. Write to: "Hoenlinger, Bertram" <hoenlinger@zeiss.de>
Bertram respond quickly through email.
