sebastianruehl Posted October 13, 2022 Share #1 Posted October 13, 2022 Advertisement (gone after registration) Hi everyone! Yep, like described above. Just picked up the M10 Monochrome last week in Wetzlar. Problem: I get a distorted image in the Visoflex2 when using the M10 Monochrome. Latest Firmware installed: 4.22.11.51 What I tried: The Visoflex2 works perfectly with my M11 and the M10R. The Visoflex 020 works perfectly with the M10 Monochrome. I would love to use just the Visoflex 2 and don't want to carry two Visoflex, since I'm only using it for my 90mm and the WATE. Thanks so much for any ideas, how to get the Visoflex2 working with my M10 Monochrome. Best regards Sebastian Link to post Share on other sites More sharing options...
Advertisement Posted October 13, 2022 Posted October 13, 2022 Hi sebastianruehl, Take a look here Trouble with M10 Monochrome and Visoflex 2. I'm sure you'll find what you were looking for!
Keith (M) Posted October 13, 2022 Share #2 Posted October 13, 2022 I recently bought M11 + Visoflex2 and as a M10M owner I obviously tried the new Visoflex2 on the M10M and having read your post I just tried it out again. Both times the combination worked perfectly. Hope you are able to find out the cause(s) of your problem. Link to post Share on other sites More sharing options...
Guest Posted October 14, 2022 Share #3 Posted October 14, 2022 Latest Firmware update is 4:22:11:52 maybe that’s the issue? Or did you mistype? Link to post Share on other sites More sharing options...
sebastianruehl Posted October 14, 2022 Author Share #4 Posted October 14, 2022 Keith: Thanks so much. Glad your setup works. It's helpful for me to know, that it does work. So, thanks for checking and your reply. OThomas: Thanks so much for reading my post "Very Carefully"! Great. Unfortunately: Mistype. Too bad. Sorry. .52 is installed. Thanks for reply. 1 Link to post Share on other sites More sharing options...
Guest Posted October 14, 2022 Share #5 Posted October 14, 2022 @sebastianruehl no problem. Easily done on the mistyping. Link to post Share on other sites More sharing options...
overexposed Posted October 15, 2022 Share #6 Posted October 15, 2022 would you mind describing "distorted" a bit more please? 1 Link to post Share on other sites More sharing options...
t00l1024 Posted February 13, 2023 Share #7 Posted February 13, 2023 Advertisement (gone after registration) I just received a Visoflex 2 and using a M10M (firmware version 4.22.23.34) and about 50% of the time I bring the Visoflex to my eye (switching between LCD and Visoflex) I get red horizontal lines across the [Visoflex] screen. I've cleaned the contacts on both the camera and Visoflex and it appears to make a solid connection when mounting it. Unsure as to the problems. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/340436-trouble-with-m10-monochrome-and-visoflex-2/?do=findComment&comment=4684049'>More sharing options...
costa43 Posted September 6, 2023 Share #8 Posted September 6, 2023 Hi, Thought I'd re-ignite this thread rather than starting a new one. I'm also having the exact same issue with my m10r and the Visoflex 2. Have you had any luck with it since? Thanks Costa Link to post Share on other sites More sharing options...
wolan Posted September 6, 2023 Share #9 Posted September 6, 2023 I have both the M10R and the M11m. With the M11m I have no problems. But with M10R the Visoflex 2 starts to behave strangely after a while that I have used the camera. If I switch the camera on, then I get the screen like when the TV set is receiving a scrambled signal. I have to wait then a few seconds before normal behaviour resumes. Occasionally, I also notice freezes that force me to extract the battery (I suspect they are caused by the Visoflex) 1 Link to post Share on other sites More sharing options...
costa43 Posted September 6, 2023 Share #10 Posted September 6, 2023 Yes, mine also scrambles and goes red. it happens often. Sometimes it resets after a shot and sometimes I have to turn off LV and turn it back on. It's usable but frustrating, I'm considering selling the Visoflex 2 and picking up the old model if there is no fix. Link to post Share on other sites More sharing options...
t00l1024 Posted September 6, 2023 Share #11 Posted September 6, 2023 I suspect the issue is on the camera side. My VF2 went back to Leica and they said there wasn't anything wrong with it, which points to the M10M. I ended up selling the VF2 to someone with a M11, and it worked great for them. Now, i just use the older model. :-( 1 Link to post Share on other sites More sharing options...
costa43 Posted September 7, 2023 Share #12 Posted September 7, 2023 17 hours ago, t00l1024 said: I suspect the issue is on the camera side. My VF2 went back to Leica and they said there wasn't anything wrong with it, which points to the M10M. I ended up selling the VF2 to someone with a M11, and it worked great for them. Now, i just use the older model. 😞 I'm thinking of doing the same. Link to post Share on other sites More sharing options...
t00l1024 Posted December 10, 2023 Share #13 Posted December 10, 2023 Digging this back up. Bought another Visoflex2 and didn’t have the issue again on the M10M so I’m stumped. Link to post Share on other sites More sharing options...
