Hey,
i was Set up for a 10 Hour Timelapse when after 2 Hours my sl2s my camera showed me the red battery symbol although I hat the camera on a powerbank with usbc .
why?
have I missed something?
i thought the usbc port gives me constant power?
2 hours ago, Photoworks said:
It will change when camera is off.
there is only a trickle charge when the camera is in use.
I guess I found the problem. You need a usb c source. If you use the standard usb for the powerbank it trickle charges. But if you use a Anker usbc powerbank with both sides usbc then the plug 🔌 sign comes up and the battery is charged. Very disturbing ….
