I am a fairly new user of a Q2 4 months now.  I like shooting Panoramic's and have with my Nikon's etc.  Was trying to set up for Q2 via an RSS Pano platform and adjust for Parallax,  not seeing a RRS camera bracket for Q2. I do see that on the menus that there is a Pano in the scene mode, Vert and Horizontal though not had had an opportunity to use it yet, Jpeg I am sure. But,  I was holding the Q2 in the Vertical position for a few seconds and all of a sudden the live view screen  goes away and a  screen resembling the start up screen with a gray scale rotating circle in the middle and rimmed on the edges a red rimmed boarder appears and then goes blank, I also show three small triangles showing up in the lower left corner.  Anyone knows why it does that or can explain that. Thanks.  Does not do this in the Horizontal orientation.
I have RRS L brackets on both of my Q2s (part number BQ2-LPG B if I read it right); allows easy Portrait and Landscape changes. They attach to the RRS pano brackets fine. B&H shows them out of stock. RRS has them listed but no indication if in stock.
Edited by rpittal
Thanks, I just found the brackets on the RSS web site, looks like they will work fine.  Also figured out the screen.  Had the Bluetooth still set from setting up the BT and paring it to the iPhone.  Turned off the BT and the screen acts as normal. With so many menus and sub-menus it is easy to get lost in them or have some set that affects something else.
