william3998 Posted March 6, 2022 Share #1 Posted March 6, 2022 Advertisement (gone after registration) I was wondering if the Q2 Lim's half case will fit in the genuine leica q2 holster? The Holster I'm referring to: https://leica-store.com.au/products/19577?gclid=CjwKCAiA1JGRBhBSEiwAxXblwcJyvxEMiKjZp_JD6nz2EnD4LN8_gaO3TDQUE9CI6eGt73xqdAvS2xoCVisQAvD_BwE Keep in mind, I do know that the Holster does have a removable insert, But i was curious if that is enough for the case to fit as I know the Lim's case is quite deep. Thanks! Link to post Share on other sites More sharing options...
Advertisement Posted March 6, 2022 Posted March 6, 2022 Hi william3998, Take a look here Does any know if the Lim's Half Case for the Leica Q2 fit in the Leica Q2 Holster? . I'm sure you'll find what you were looking for!
Ning Ning Posted March 6, 2022 Share #2 Posted March 6, 2022 To be honest, I can't imagine that. I have the Q2 with the grip in the holster and it sits firmly in it. Since the Lim's half case is thicker, you will have to force the Q2 into the holster, if at all. Link to post Share on other sites More sharing options...
william3998 Posted March 6, 2022 Author Share #3 Posted March 6, 2022 @Ning NingI see. And in your case, this is also removing the removable insert from the holster in order to fit it in? And what holster/grip are you using, I might just get the same one so i can void headache of returning the Lim's if it doesn't fit Link to post Share on other sites More sharing options...
Ning Ning Posted March 7, 2022 Share #4 Posted March 7, 2022 Yes, you have to remove the insert from the Leica holster so that the Q2 can be inserted with the Leica handgrip. I still have the Leica finger loop on the original handgrip for the Q2. Link to post Share on other sites More sharing options...
