The only M lens that I do not find corrections for in Lightroom is my 24mm ASPH 2.8.   Do any of you reading this note have a set you can post and tell me where to find a set I can load into Lightroom.    I got the lens when 24mm corresponded to the widest frame lines in my M8.  Now I find I use it as much as any in my 35,50,75,90 mm set.
The 24 Elmarit f/2.8 ASPH had a really oddball optical formula unlike anything else Leica ever made for the M - about a 1-inch/2.5cm gap between the front element and all the rest of the glass. Almost a throwback to 1960s SLR retrofocus designs (e.g. Leica's 1964 R-system 35 f/2.8) - although much sharper and contrastier (the lens for which Erwin Puts first adopted the word "clinical" ;) ).
http://www.summilux.net/m_system/images/Elmarit24Asph.pdf
Depends on which corrections are needed: vignetting, color vignetting, distortion.
Distortion was pretty unique as well - strong (2% barrel)"handlebar moustache" distortion that never fully corrects back to the corners. No perfect match among recent M lenses, although it falls in between the 28mm Summilux (less) and the 24mm Summilux (even more).
For vignetting, the 24mm f/3.8 Elmar-M (but also the Summiluxes) is probably a pretty close match.
The digital-M in-camera profile should take care of color vignetting problems (and some general vignetting) even before the file is written to the SD card.
All the same, the 24 Elmarit had its fans, Erwin Puts among them, and Mary Ellen Mark. In 2002, Erwin had this to say: “The Elmarit-M is without a doubt a masterpiece of optical engineering, a landmark design within the Leica M range”.
Edited by graphlex
Add Erwin Puts quotation.
