I use the SF 40 with my X-Vario for off flash use and is is great.  I can't imagine needing more features or power unless you are a pro.
I have also bought the Godox Nikon 1.5m cord for hand holding the flash for off camera when I want full TTL and no direct trigger flash.   Pointing 2 gadgets at a target at the same time with 2 hands ain't EZ.
Hope this helps.  Keep in mind that the SF 40 does not work with Leica's wireless trigger.
If you already have Godox X system flashes, just get an X-Pro trigger for Nikon.  I use these across all of my Leicas and they work great in manual mode.  If you need TTL, then you’re stuck with Leica lights, unfortunately.  But I find using manually controlled strobes to be better for when I need them.  TTL has never given me great exposures in a studio setting.
I do have the triggers for Sony and Fuji. Will that work or do I need the Nikon? Also, how about pocket wizards? I do have a few, Will they work?
