2 minutes ago, Boojay said:
Yes Please!!!!   They can call it what they like.
they seem way too scared about other models eating into M sales, this concept [36MP APS-C Native M mount] of a CL2 could be a limited run or whatever and would prolly be sold out within days
x
22 hours ago, frame-it said:
- 発表は2023年の5月 / 6月頃の予定
- ライカM11と同じセンサーと画像処理エンジンを採用
- ボディとレンズ、手ブレ補正はライカQ2と同じ
- コードネームはWilson
- 価格はQ2(現在5795ドル)よりも高くなる
- 可動式液晶モニタ
- より高解像度のEVF
- メモリー内蔵
- USB充電対応
- 8K動画は非搭載
- 位相差AF
- ワイヤレス充電可能な新型ハンドグリップ
- バッテリーは同じライカBP-SCL4リチウムイオン電池だが、よりハイパワー/mAhになっている
ライカQ3はレンズはQ2と同じもののようですが、M11と同じ6000万画素センサーと画像処理エンジンが採用され、位相差AFにも対応するということで、結構大きなモデルチェンジになりそうです。また、モニタが可動式になるのもQ2との大きな違いですね。
   to be announced around May/June 2023
- same sensor and image processing engine as the Leica M11
- Same body, lens and image stabilization as Leica Q2
- Codename Wilson
- Price will be higher than Q2 (currently $5795)
- Movable LCD monitor
- higher resolution EVF
- Built-in memory
- Supports USB charging
- 8K video not installed
- Phase detection AF
- New handgrip with wireless charging
- The battery is the same Leica BP-SCL4 Lithium Ion but with higher power/mAh
The Leica Q3 seems to have the same lens as the Q2, but it seems to be a pretty big model change because it uses the same 60-megapixel sensor and image processing engine as the M11, and it also supports phase detect AF. Another big difference from the Q2 is that the monitor is movable.
Back to the interesting stuff*. I would be happy with all of this except the LCD monitor: a mechanical extra that can go wrong and takes up bulk.
However.......
I see nothing that says the 30 minute limit on video has been removed. It may have been there not for historical regulatory reasons but for heat management reasons. An articulated monitor could take some heat generation away from the body, and so allow long video.
We can but hope!
I'm all good with the rest, as long as there is enough grunt in the processor to handle better AF (which is the Achilles heel of the Q2).
Interesting to see the comment about the battery: I hope a higher capacity battery would work in the SL2-S / SL3 as well.
*Not the "M with a L mount", "Q with interchangeable lenses", "SL in M format", "full frame CL" which have been done to death in this forum. Nothing wrong with them, and the threads all show the pent up demand for a small mirrorless ILC from Leica. But I want to keep on track with the Q3!
If it's flush to the camera, like 99.9% of all modern screens, how does it take bulk?
Besides, the weakest hardware point in all Leica cameras is the rangefinder. Drop your camera and there's a substantial chance it will get misaligned. That is, if it's not misaligned right out of the box, like some users have experienced. Should Leica remove the rangefinder for a more robust EVF too?
Because a movable screen needs two extra layers of body shield? And space for a hinge?
I'm not sure where a rangefinder came into the conversation: a M is not weather resistant either, but I'm not expressing an opinion about the M design - we're talking about a Q.
My comments and personal preferences are just that. I doubt Leica has taken them into account, and it's a bit late for a redesign now to accommodate them. Nor is it an issue that would sway my decision to buy either way.
like a 36MP APS-C Native M mount CL2
Why not just call it a CL2 and continue with the M adaptor? Then existing T - CL owners could keep using their TL lenses. Oh wait…Leica cancelled that idea…
I would happily consider an SL3 that was significantly lighter and smaller and with the technology upgrades to make it competitive, but I suspect they don’t have the resources even with Panasonic as a partner to make that happen.
  • 1 month later...
On 3/27/2023 at 11:55 PM, Le Chef said:
Like most gossip, the same details get passed around in ever-expanding circles until no one can say for sure where the claims came from. I’ve yet to see anyone authenticate the claims being made, so have to assume it’s fiction created as clickbait.
well., lets see what is revealed on the 25th
