Adz Posted November 26, 2021 Share #1 Posted November 26, 2021 Advertisement (gone after registration) Hi, just purchased the 1150 casing, and tried to fit the M10p with a Voigtlander 35mm f1.2 Mk3 into the casing. I noticed that some force is needed to compress the foam and more when trying to lock the case. Wondering if such compression would spoil the top dials and shutter button of the M10p in the long run? I thought I might need to trim off some foam from the top and bottom cushion. Then again I seen some guys using the 1150 for their Ms. I can't be sure how's its being placed. The image attached shows how I'm intending to place the camera in the case. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/326960-pelican-1150-and-leica-m10-p/?do=findComment&comment=4320699'>More sharing options...
Advertisement Posted November 26, 2021 Posted November 26, 2021 Hi Adz, Take a look here Pelican 1150 and Leica M10-P . I'm sure you'll find what you were looking for!
FrozenInTime Posted November 26, 2021 Share #2 Posted November 26, 2021 I use a thin pouch for the camera normally, and this fits in the 1150 with no foam. Link to post Share on other sites More sharing options...
Pixeleater Posted November 26, 2021 Share #3 Posted November 26, 2021 Your case dimensions are below and the foam decreases available space, as you noted. I ended up with the iM2100 Storm Case. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/326960-pelican-1150-and-leica-m10-p/?do=findComment&comment=4320744'>More sharing options...
Adz Posted November 26, 2021 Author Share #4 Posted November 26, 2021 7 minutes ago, FrozenInTime said: I use a thin pouch for the camera normally, and this fits in the 1150 with no foam. having the foam seems easier to use. I tried without the foam and yes it fits inside. minus the protection. Might have to do your method. does it move around inside the case? Link to post Share on other sites More sharing options...
Adz Posted November 26, 2021 Author Share #5 Posted November 26, 2021 7 minutes ago, Pixeleater said: Your case dimensions are below and the foam decreases available space, as you noted. I ended up with the iM2100 Storm Case. Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Yes. the foam decreases the depth. Hence wondering those who use, do they just compress and close, but will it do harm to the body or maybe cutting some top and bottom foam to ease the pressure on the body when closed but yet some foam providing protection still. Let me see the im2100 Link to post Share on other sites More sharing options...
Pixeleater Posted November 26, 2021 Share #6 Posted November 26, 2021 (edited) Check this thread for additional insight: Edited November 26, 2021 by Pixeleater Link to post Share on other sites More sharing options...
Pixeleater Posted November 26, 2021 Share #7 Posted November 26, 2021 Advertisement (gone after registration) Here is an alternate that may work for you? It's the Pelican iM2050 Storm Case. A smaller case than the iM2100. iM2100 Exterior 14.2 x 11.4 x 6.5" / 36.1 x 29 x 16.5 cmInterior 13 x 9.2 x 6" / 33 x 23.4 x 15.2 cm iM2050 Exterior 11.8 x 9.8 x 4.7" / 30 x 24.9 x 11.9 cmInterior 9.5 x 7.5 x 4.2" / 24.1 x 19.1 x 10.7 cm 1.5" / 3.8 cm (Lid Depth) 2.75" / 6.99 cm (Base Depth) Link to post Share on other sites More sharing options...
Adz Posted November 26, 2021 Author Share #8 Posted November 26, 2021 21 minutes ago, Pixeleater said: Check this thread for additional insight: Read that post. custom foam. might need to do one but I'm trying to see if can use stock one. Link to post Share on other sites More sharing options...
Adz Posted November 26, 2021 Author Share #9 Posted November 26, 2021 8 minutes ago, Pixeleater said: Here is an alternate that may work for you? It's the Pelican iM2050 Storm Case. A smaller case than the iM2100. iM2100 Exterior 14.2 x 11.4 x 6.5" / 36.1 x 29 x 16.5 cmInterior 13 x 9.2 x 6" / 33 x 23.4 x 15.2 cm iM2050 Exterior 11.8 x 9.8 x 4.7" / 30 x 24.9 x 11.9 cmInterior 9.5 x 7.5 x 4.2" / 24.1 x 19.1 x 10.7 cm 1.5" / 3.8 cm (Lid Depth) 2.75" / 6.99 cm (Base Depth) how about 1200? Link to post Share on other sites More sharing options...
Pixeleater Posted November 26, 2021 Share #10 Posted November 26, 2021 13 minutes ago, Adz said: how about 1200? Exterior 10.6 x 9.7 x 4.9" / 26.9 x 24.6 x 12.5 cmInterior 9.3 x 7.1 x 4.1" / 23.6 x 18 x 10.4 cm Link to post Share on other sites More sharing options...
pgk Posted November 26, 2021 Share #11 Posted November 26, 2021 I have innumerable 1400s which take varioys camera bodies and lenses very happily and so are versatile, but still quite small, lght and manageable. I do not like to have anything pushing down continuously on the shutter release of any camera myself. Link to post Share on other sites More sharing options...
jkcampbell2 Posted November 26, 2021 Share #12 Posted November 26, 2021 Pelican's TreckPac dividers make a great way to layout your case plus it's easy to change the design as equipment changes. The system is a bit expensive but a DIY version is pretty easy to make. https://www.arielestulin.com/diy-trekpak-for-under-20/ Cheers! jc 1 Link to post Share on other sites More sharing options...
denton Posted December 3, 2021 Share #13 Posted December 3, 2021 My second to the TrekPak system. This allows much more compact arrangement and gives better room without too much foam. The system is nearly infinitely customizable. And besides it was invented by my daughter. Denton 3 Link to post Share on other sites More sharing options...
cboy Posted December 4, 2021 Share #14 Posted December 4, 2021 A 1170 fits a m body ( flat) with 50mm lens perfectly. 🙂 Link to post Share on other sites More sharing options...
