iek1968 Posted November 25, 2021 Share #1 Posted November 25, 2021 Advertisement (gone after registration) Does someone know in which direction I should turn the rf adjusting screw and in what inrements? Thanx! Link to post Share on other sites More sharing options...
Advertisement Posted November 25, 2021 Posted November 25, 2021 Hi iek1968, Take a look here Leica III backfocuses around 4 cm. I'm sure you'll find what you were looking for!
qqphot Posted December 5, 2021 Share #2 Posted December 5, 2021 I forget which direction but it will be quite apparent once you try - set the lens against the infinity stop aimed at a very distant (1km +) object and adjust the rf adjusting screw one direction or another in miniscule increments, barely even more than steady pressure, perhaps 1/32nd of a turn at a time and it will be clear which direction brings the split images together until they are perfectly in register. I haven't ventured into messing with the focus arm length adjustment because I worry I'd make things worse and the infinity adjustment seems to be sufficient for me every time focus accuracy drifts off. Link to post Share on other sites More sharing options...
iek1968 Posted December 5, 2021 Author Share #3 Posted December 5, 2021 vor 11 Stunden schrieb qqphot: I forget which direction but it will be quite apparent once you try - set the lens against the infinity stop aimed at a very distant (1km +) object and adjust the rf adjusting screw one direction or another in miniscule increments, barely even more than steady pressure, perhaps 1/32nd of a turn at a time and it will be clear which direction brings the split images together until they are perfectly in register. I haven't ventured into messing with the focus arm length adjustment because I worry I'd make things worse and the infinity adjustment seems to be sufficient for me every time focus accuracy drifts off. Ok thanks, I did it, it was pretty easy, but only my trusty Wiha 1mm screwdriver fit thru the hole. But then it got hold tightly of the adjustment screw. Question: I thought the Screwmount Leicas dont have a focus arm length adjustment, just the Ms do, am I wrong? Greetings Link to post Share on other sites More sharing options...
