wolan Posted September 23, 2021 Share #1 Â Posted September 23, 2021 Advertisement (gone after registration) Hi, I shot a lot with manual lenses and the magnification feature offered by many today's mirrorless cameras is key for me in getting sharp pictures. The SL2-s would be an almost perfect tool for manual shooters except for the following really annoying quirknesses, that could be fixed with a few hours of work on the firmware. Joystick magnification: it magnify always at the maximum available, why?? One can reduce the magnification with the thumbwheel, however next time it will default on the maximum. Joystick magnification: If you click one time it magnifies, however if you push again nothing happens, why??? The same however works when you are reviewing a picture, so why do not they make it consistent?? Magnification via reassigned key: it works and it saves the magnification level you have used last time, however if you accidentally push the Joystick and then customised key it defaults again on the maximum magnification Magnification with thumbwheel is the perfect solution for the manual shooter, however it does not work if you are not using the Leica L->M adapter. However, it actually works if you remap one of the customisable front key, that means it is not a problem of compatibility, it is just that the implementation is broken. Related to this, when using a non-Leica L->M adapter: the settings Wheel Assignment MF-Lens is ignored and the setting Wheel Assignment AF-lens is used under Customise control, although I am clearly using a manual lens. It would take very little to make it perfect, I hope Leica will work on this in next firmware versions. By the way, where can one submit suggestions and request for enhancements? Thanks. Â 2 Link to post Share on other sites More sharing options...
Advertisement Posted September 23, 2021 Posted September 23, 2021 Hi wolan, Take a look here Quirknesses of the SL2-s magnification system. I'm sure you'll find what you were looking for!
52K Posted September 24, 2021 Share #2  Posted September 24, 2021 Submit requests and feedback via Leica fotos app. I also find the magnification issue back to front when not using the L-M adapter and lack of DOF preview when using a lens with electronic aperture blades. 1 Link to post Share on other sites More sharing options...
