MarkWood1 Posted September 10, 2021 Share #1 Posted September 10, 2021 Advertisement (gone after registration) Hi, When using the Q2 on manual, as I do, there is the option to set your desired ISO setting. The factory set range goes 200-400-800-1600 etc. Can this be tweeked to set an ISO that is not in that range, for instance a setting of ISO1000. Thanks Link to post Share on other sites More sharing options...
Advertisement Posted September 10, 2021 Posted September 10, 2021 Hi MarkWood1, Take a look here Leica Q2 and the ISO settings . I'm sure you'll find what you were looking for!
Anakronox Posted September 10, 2021 Share #2 Posted September 10, 2021 Not manually. Incremental values between full stops are only possible in auto ISO mode. Link to post Share on other sites More sharing options...
MarkWood1 Posted September 11, 2021 Author Share #3 Posted September 11, 2021 On 9/10/2021 at 12:01 PM, MarkWood1 said: Hi, When using the Q2 on manual, as I do, there is the option to set your desired ISO setting. The factory set range goes 200-400-800-1600 etc. Can this be tweeked to set an ISO that is not in that range, for instance a setting of ISO1000. Thanks omegle thankyou Link to post Share on other sites More sharing options...
