liggy Posted August 12, 2022 Share #21 Posted August 12, 2022 Advertisement (gone after registration) 3 hours ago, Camaro5 said: I didn't like the PD anchors when they were put through the lugs by themselves. Didn't seem to give enough flexibility. With the triangular D-rings and the anchors the strap moves more freely. The D-rings have plastic protectors on the backs of them and I haven't yet seen any wear on my Q2 or M10-R. That’s funny - I felt like the triangles provided too much movement. And I don’t really love the sound of them moving around either. Different strokes. Link to post Share on other sites More sharing options...
Advertisement Posted August 12, 2022 Posted August 12, 2022 Hi liggy, Take a look here Peak Design anchors and Q2 lugs . I'm sure you'll find what you were looking for!
alex dey Posted September 30, 2022 Share #22 Posted September 30, 2022 as someone with extensive experience putting thick things through tight spaces, and as both a q2 and pd owner, i can attest it can indeed be done. use dental floss to thread the leads, and then with a thumbtack push it through. i promise it works. 1 Link to post Share on other sites More sharing options...
trstahly Posted October 1, 2022 Share #23 Posted October 1, 2022 I have dozens of PD anchors and use the older ones with thinner material. I do my best to get the ends squished as small as I can and then push them though with a paperclip and it worked on my Q2 and Q2M. Link to post Share on other sites More sharing options...
cdnchris Posted February 28, 2023 Share #24 Posted February 28, 2023 The dental floss trick worked for me on my M4-2! Thank you! Link to post Share on other sites More sharing options...
joshkerr Posted June 23, 2023 Share #25 Posted June 23, 2023 I just recently upgraded my Q2 to the Q3 and struggled to get the Peak Design adapter through the eyelet. Thank you so much for the tip to use dental floss. This worked perfectly for me. Link to post Share on other sites More sharing options...
kirkmc Posted June 23, 2023 Share #26 Posted June 23, 2023 I use small O rings to which I connect the anchors. I like the flexibility of Peak Design straps, and I have one of these on order: https://www.kickstarter.com/projects/peak-design/micro-clutch-hand-strap-for-mirrorless-cameras/description Link to post Share on other sites More sharing options...
oldsalt Posted June 23, 2023 Share #27 Posted June 23, 2023 Advertisement (gone after registration) The dental floss "technique" worked for my Q2... you have to put a bit of muscle into it... !!! cheers Link to post Share on other sites More sharing options...
