charles tay Posted August 12, 2021 Share #1 Â Posted August 12, 2021 Advertisement (gone after registration) Have anyone used Voiglander 10mm f5.6 on their Leica M10? Is it hard to focus on a 10mm lens? Link to post Share on other sites More sharing options...
Advertisement Posted August 12, 2021 Posted August 12, 2021 Hi charles tay, Take a look here VOIGTLANDER 10mm F5.6 Heliar Hyper Wide VM. I'm sure you'll find what you were looking for!
Ecar Posted August 12, 2021 Share #2  Posted August 12, 2021 Never used it, but I believe it is not RF coupled. DoF on such a lens will be huge, so it should be VERY forgiving in terms of focus. I would just estimate the distance and roughly scale focus but if you are very picky, you could probably further refine focus through LV/EVF. Link to post Share on other sites More sharing options...
charles tay Posted August 12, 2021 Author Share #3  Posted August 12, 2021 32 minutes ago, Ecar said: Never used it, but I believe it is not RF coupled. DoF on such a lens will be huge, so it should be VERY forgiving in terms of focus. I would just estimate the distance and roughly scale focus but if you are very picky, you could probably further refine focus through LV/EVF. which means we cant use the RF but have to use peak focusing instead right? Link to post Share on other sites More sharing options...
Ecar Posted August 12, 2021 Share #4  Posted August 12, 2021 (edited) 1 hour ago, charles tay said: which means we cant use the RF but have to use peak focusing instead right? Not quite. Yes, the RF will be useless. The patch will not move as there is no link between the lens helicoid and the RF cam inside the body. However, I don't think that focus peaking will be of much use either: at f/5.6 on such a short focal length, pretty much the whole frame will appear in focus. I would just estimate the distance from your subject and set the distance scale on the lens accordingly. If your subject is very close and/or you want to make sure that you have absolutely perfect focus, then you could look through the EVF (or on the LV screen) to adjust. But I would deactivate focus peaking to avoid the coloured clutter and just rely on my eyes. Edited August 12, 2021 by Ecar 1 Link to post Share on other sites More sharing options...
wda Posted August 12, 2021 Share #5  Posted August 12, 2021 If you do need to focus with a 10mm lens, I would use Live-view. 1 Link to post Share on other sites More sharing options...
Jean-Michel Posted August 12, 2021 Share #6  Posted August 12, 2021 Well, you would view either through an EVF or the rear screen. It is just about impossible to have anything out of focus using a 10mm at f/5.6 — with the lens at 1 meter, everything from about 40 cm to infinity would be in focus, stopping down would extend the near limit further. 1 Link to post Share on other sites More sharing options...
