thebaileyhayden Posted August 10, 2021 Share #1  Posted August 10, 2021 Advertisement (gone after registration) Hi,  I recently purchased some Leica R lenses which have been Declicked and dampened and given an EF mount.  I wondered if it is possible to use an adapter to mount the R's on an M6 body as they now have EF mounts.  Thanks, Bailey Link to post Share on other sites More sharing options...
Advertisement Posted August 10, 2021 Posted August 10, 2021 Hi thebaileyhayden, Take a look here Can I use Cini-vised Leica R lens with EF mount on M6 Body. I'm sure you'll find what you were looking for!
BernardC Posted August 10, 2021 Share #2  Posted August 10, 2021 1 hour ago, thebaileyhayden said: I wondered if it is possible to use an adapter to mount the R's on an M6 body as they now have EF mounts. You can find some cheap EOS-to-Leica M adapters. The problem is that you won't be able to focus the lenses via the M6's rangefinder, and the focus scales on the lenses won't be accurate (that's an issue with all adapters, but especially with cheap adapters). Did the lenses come with their original parts, so you can convert them back to R mount? If that's the case, you may have better luck converting them back and using Leica's "R Adapter M." It's a very expensive adapter, but it's much more likely to be built to the right tolerances. Even then, you will want to calibrate them on a digital M so that you can see if any focus compensation is required. You may find, for instance, that you need to turn the focus scale by a few millimeters (always in the same direction) to get perfect focus. 1 Link to post Share on other sites More sharing options...
Einst_Stein Posted August 10, 2021 Share #3  Posted August 10, 2021 Get a SLR film camera. Link to post Share on other sites More sharing options...
