pgk Posted June 25, 2021 Share #1  Posted June 25, 2021 Advertisement (gone after registration) In the M lens forum I commented that the 75mm Summilux provides really nice ergonomics/balance on the SL and is a pleasant combination to use. I suspect that the same would be true of the lates two models of the 90mm Summicron (pre- and aspheric). Can anyone suggest complimentary 20/21 and 35 M fit lenses (not necessarily Leica) which also balance well and are comfortable in use? I do not need AF so M lenses are fine and bulk/weight actually helps on the SL IMO, as it pushes balance forward and away from the relatively weighty body and drops the lens nicely into the hand. Link to post Share on other sites More sharing options...
Advertisement Posted June 25, 2021 Posted June 25, 2021 Hi pgk, Take a look here The SL, manual focus M fit lenses and balance/ergonomics.. I'm sure you'll find what you were looking for!
