labyrinth Posted September 30, 2021 Share #21  Posted September 30, 2021 Advertisement (gone after registration) 10 hours ago, Infantasy said: I was able to dissemble the pre-FLE except the retaining ring for the circled parts. I had used calipers to open but unsuccessful. It was very tight or may be at the wrong side. Would you please advise it should be turned clockwise or anti-clockwise? Oh, I see. That one was tough on my version as well, I used a chinese spanner to get a better grip. The thread is regular so go anti-clockwise to unscrew it Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Link to post Share on other sites Simply register for free here – We are always happy to welcome new members! ' data-webShareUrl='https://www.l-camera-forum.com/topic/322018-partial-disassembly-leica-summilux-m-50mm-f14-asph/?do=findComment&comment=4284402'>More sharing options...
Advertisement Posted September 30, 2021 Posted September 30, 2021 Hi labyrinth, Take a look here Partial disassembly - Leica Summilux-M 50mm f/1.4 ASPH.. I'm sure you'll find what you were looking for!
Infantasy Posted October 1, 2021 Share #22  Posted October 1, 2021 6 hours ago, labyrinth said: Oh, I see. That one was tough on my version as well, I used a chinese spanner to get a better grip. The thread is regular so go anti-clockwise to unscrew it Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! Noted with thanks Link to post Share on other sites More sharing options...
Infantasy Posted October 3, 2021 Share #23  Posted October 3, 2021 The retaining ring is very tough to open. I tried several times and eventually given up this make the focusing not very smooth as the lubricant may be dried already. On 9/30/2021 at 8:50 PM, Infantasy said: labyrinth, I was able to dissemble the pre-FLE except the retaining ring for the circled parts. I had used calipers to open but unsuccessful. It was very tight or may be at the wrong side. Would you please advise it should be turned clockwise or anti-clockwise? Welcome, dear visitor! As registered member you'd see an image here… Simply register for free here – We are always happy to welcome new members! On 9/30/2021 at 6:07 PM, labyrinth said: Hi there, When I open up my precious lenses I usually do not mess with the optics so there is not much left to play around when you disassemble mechanics, particularly for non-FLE version all you do is remove the flange rotate the focus ring until it's off then loosen the ring with a spanner or calipers whatever you have at your disposal and remove that aluminum heli part then take the brass lock ling off and you are there. Refer to this disassembly pics of this technician. There is not much to grease when speaking about aperture ring just a small trace for the metal ball to slide around. I think not worth the effort.  regards labyrinth, I was able to dissemble the pre-FLE except the retaining ring for the circled parts. I had used calipers to open but unsuccessful. It was very tight or may be at the wrong side. Would you please advise it should be turned clockwise or anti-clockwise? Link to post Share on other sites More sharing options...
