Guest hagen Posted August 29, 2007 Share #21 Posted August 29, 2007 Advertisement (gone after registration) I got the Vulcanite from the CS in Solms (beta test) and the bleached logo is the logo of the Titanium M7. A kind of a la card for poor people Link to post Share on other sites More sharing options...
Advertisement Posted August 29, 2007 Posted August 29, 2007 Hi Guest hagen, Take a look here M8 vinyl vulcanite. I'm sure you'll find what you were looking for!
monza Posted August 29, 2007 Author Share #22 Posted August 29, 2007 I got the Vulcanite from the CS in Solms (beta test) and the bleached logo is the logo of the Titanium M7.A kind of a la card for poor people Do they need another beta tester? Of course I'd need to acquire an M8 first... The Luigi case might be a good solution for me. To be honest I didn't really like the grip, either. If the shutter button were on the top of the grip cylinder, yes. Someone needs to design a better grip... Link to post Share on other sites More sharing options...
gravastar Posted August 29, 2007 Share #23 Posted August 29, 2007 Bob, any idea what the warranty problem is? I assume Leica will not provide warranty service for cameras with it on, but after our warranties have expired, I don't see what the problem is. Besides, I have one M8 which is well out of warranty already... I have a faint recollection it could have been the screws being covered as mentioned by another poster. The information came from a person on the rangefinder forum, but I'm not able to find the details. As you say after the expiry date it shouldn't matter except Leica would probably insist on charging for cleaning off the old cover and adhesive and a standard replacement set etc. Bob. Link to post Share on other sites More sharing options...
marknorton Posted August 29, 2007 Share #24 Posted August 29, 2007 The only thing preventing a "clean run" of an after-market covering is the frame preview lever. The rest will fit easily, though I think the extreme thinness around the base of the lens mount would be a challenge. As regards the screws, there used to be 4 on the front, 2 each side of the lens, now there are 3 each side at the back. I agree that the choice of adhesive is crucial. It needs to hold the covering securely yet allow the material to be peeled back without stretching and leaving a residue. Link to post Share on other sites More sharing options...
mtwo Posted August 30, 2007 Share #25 Posted August 30, 2007 the modified camer does indeed look very nice and reminiscent of an older Leica. Even the Logo is neat. That being the case. There are a couple of things users can do to make the camera less "slippery". First: put the damn strap around your neck or wrap it around your wrist. Neck is preferable. I admit to not doing this but it is sensible behavior and you gotta admit that you are not likely to drop it if you use the strap. Second: consider a tripod adapter. I bought the Kirk. Nicely machined, fits. works in my tipod head very well and gives you a vey nice hand hold. One finger around the lens the middle finger around the Kirk plate and you have a very steady grip. Leica needs a bump on the right side of the camera ala a Nikon F3 but suspect that would destroy the mystique. What do you use, not one of those cases, I hope. John Link to post Share on other sites More sharing options...
monza Posted August 30, 2007 Author Share #26 Posted August 30, 2007 [quote=mtwo;342473There are a couple of things users can do to make the camera less "slippery". First: put the damn strap around your neck or wrap it around your wrist. Leica needs a bump on the right side of the camera ala a Nikon F3 but suspect that would destroy the mystique. Yes, use of neck strap is a given. The grip should be designed with the F3 style bump instead of a cylinder... Link to post Share on other sites More sharing options...
monza Posted August 30, 2007 Author Share #27 Posted August 30, 2007 Advertisement (gone after registration) I wandered over to Tom A's site (rapidwinder.com) and it says he's working on an M8 grip as he found the M8 slippery, too. Link to post Share on other sites More sharing options...
simon_hughes Posted September 1, 2007 Share #28 Posted September 1, 2007 Here's a cheap yet effective solution to the slippery M8 accessory grip: Go your local skateboard shop and ask for "grip tape". It comes typically in 8" width rolls but, of course you only need a few inches, and indeed they handed it to me at no charge! It is like sandpaper with adhesive on the back, and matches the black surface of the M8 almost perfectly! Cut a piece to fit, (I cut mine to wrap around but not overlap the rear spine), heat it up a bit with a hair dryer and then peel off the backing and wrap around the grip. Voila, makes it very non-slippery. I'm toying with adding a small patch on the upper rear position of the body (just to the right of the "Made in Germany") to give a thumb grip too. Cheers, Simon Link to post Share on other sites More sharing options...
Daniel Ortego Posted October 10, 2007 Share #29 Posted October 10, 2007 The embossed black leather makes all the difference in the world. Likewise, the logo treatment was a bold and successful touch. I’m now considering a similar look. Regards, Link to post Share on other sites More sharing options...
sparkie Posted October 10, 2007 Share #30 Posted October 10, 2007 I got the Vulcanite from the CS in Solms (beta test) and the bleached logo is the logo of the Titanium M7.A kind of a la card for poor people did you get titanium logo from solms also. and how about fitting it, did you do it or solms. i think you have to take the camera apart in order to change the logo out or am i wrong? Link to post Share on other sites More sharing options...
sparkie Posted October 10, 2007 Share #31 Posted October 10, 2007 AFAIK, there is no a la carte service available for the M8, though they are offering an engraving service for the camera top.. whats involved in this. ddo you send your camera in Milton Keynes or Solms, or you dealer? can you order a new M8 with this engraving and any idea of costs? Link to post Share on other sites More sharing options...
newyorkone Posted October 10, 2007 Share #32 Posted October 10, 2007 I got the Vulcanite from the CS in Solms (beta test) and the bleached logo is the logo of the Titanium M7.A kind of a la card for poor people Looks very sharp. Almost makes me want a silver M8 Link to post Share on other sites More sharing options...
cmogi10 Posted October 10, 2007 Share #33 Posted October 10, 2007 cameraleather.com Leica Recovering Service Link to post Share on other sites More sharing options...
gesper Posted October 11, 2007 Share #34 Posted October 11, 2007 I use a grip and a leicagoodies sling (one finger only). Very secure. Link to post Share on other sites More sharing options...
Philinflash Posted October 11, 2007 Share #35 Posted October 11, 2007 Is it just me or is the M8 rather slippery?... I am sure it was just SPS [sweaty Palms Syndrome]. Link to post Share on other sites More sharing options...
