photonc Posted April 19, 2021 Share #1 Posted April 19, 2021 Advertisement (gone after registration) Couple of quick question for the SL2 pros out there. I have looked in the manual but can't seem to find this info. 1) Is there a way to assign ISO to a dial for direct adjustment without having to press a button first? This is really key for me when using MF lenses to have access to the exposure triangle without having to press any buttons. 2) Focus point reset - I would like to have the option to rest the focus point to center in single point AF mode. I know you can double tap the screen to do this but I normally I turn the touch functionality off to ensure I don't accidently bump anything. Many thanks in advance for your help. Link to post Share on other sites More sharing options...
Advertisement Posted April 19, 2021 Posted April 19, 2021 Hi photonc, Take a look here SL2 - Changing ISO & Focus Point Reset Questions. I'm sure you'll find what you were looking for!
Photoworks Posted April 19, 2021 Share #2 Posted April 19, 2021 3 minutes ago, photonc said: 2) Focus point reset - I would like to have the option to rest the focus point to center in single point AF mode. I know you can double tap the screen to do this but I normally I turn the touch functionality off to ensure I don't accidently bump anything. There is no 1) Is there a way to assign ISO to a dial for direct adjustment without having to press a button first? This is really key for me when using MF lenses to have access to the exposure triangle without having to press any buttons. No. not sure you would want to anyway since it only adjust bu full stop. but auto iso works well for me. 2) Focus point reset - I would like to have the option to rest the focus point to center in single point AF mode. I know you can double tap the screen to do this but I normally I turn the touch functionality off to ensure I don't accidently bump anything. There is no other way to reset or lock the AF point Link to post Share on other sites More sharing options...
photonc Posted April 21, 2021 Author Share #3 Posted April 21, 2021 Thanks @Photoworks Link to post Share on other sites More sharing options...
