35 APO-M performs well on a 44x33 mm sensor (Hasselblad X, Fuji GFX)
Just a small note that the 35 APO-M casts an image circle large enough to cover a 44x33 mm medium-format sensor with only moderate vignetting in the corners and moderate purple color cast in the corners, both removable in post, for those who want to shoot it on a medium format sensor or film.
On 4/15/2021 at 5:33 AM, frame-it said:
Thanks for the link but my experience with the 50 Leica Apo in 44x33 is full coverage , no vignetting no smearing, just fine .
I find Jeffo's list on Fujifilm GFX Madness facebook group quite helpful:
https://www.facebook.com/groups/1787749571545651/permalink/1792943664359575
Edited by JMF
Would you share please some photos ?
Best, JM.
Are you taking about close distance wide open where most full frame lenses work on the GFX or at infinity stopped down?
Edited by hdmesa
It actually performs well at a variety of distances and apertures.  Most Leica M lenses do NOT work without cropping on X1D/GFX sensors at any distance or aperture:
WATE at 16 or 18 mm: NO
*WATE at 21 mm: YES, some vignetting
21/3.4: NO
24/3.8: NO
28/1.4: NO
28/2: YES, but with strong vignetting especially at or near infinity, and at wide apertures
28/2.8: YES, but with strong vignetting and purple corners
Stemar: YES, but the divider produces some artifacts at top of the frame. Still, it's very cool to generate 3-D stereo image pairs using this old Leica lens and a current medium-format sensor!
MATE at 28: NO
MATE at 50: YES, but only at near distances
MATE at 35: YES, but with strong vignetting at the very corners
35/1.4: YES at closer distances or apertures around f/2.8, with some color shift
*35/2: YES, with some vignetting
*35/2 APO: YES, with modest vignetting and some purple cast in the corners
50/0.95: NO
*50/1.4: YES, with only slight vignetting at infinity
50/2 APO: YES, but only between f/3.5-6.3
*50/2.8: YES, a little vignetting wide open at infinity
*75/1.25: YES, slight vignetting at infinity
75/1.4: YES, but only around f/2.8 and at close distances
*75/2 APO: YES, almost perfect until f/8, only slight vignetting
*90/2 APO: YES, with only slight vignetting
90/2.4: YES, but only at mid/near distances
90/4: NO
135/3.4 APO: NO
Overall, the lenses I marked with an asterisk are the most useable: the WATE at 21 mm, the 35/2, 35 APO, 50/1.4, 50/2.8, 75/1.25, 75 APO, and 90 APO. Which is really a not a bad outfit if your goal is to shoot your small Leica M lenses on a cropped medium format sensor at a range of focal lengths.
  • Thanks 2
Seems to be a disconnect between different users' experience with the Leica 50 APO on 44x33. I wonder if it has anything to do with:
  • Using a 50S/R versus the GFX100/100S (100/S BSI sensor should be better at capturing the more severe angles of light in the corners)
  • Adapter quality/accuracy for infinity focus
  • Those seeing good corner performance are testing using landscapes/scenes where the land/scene is closer to the camera in the corners, thereby making good use of field curvature (if there is any) at the edges of 44x33
  • Focusing differences: optimal focus distance for 44x33 may be less forgiving – maybe before the hard stop – or focus may need to be done at the corners versus the center
Edited by hdmesa
I’m trying to word this in a way that doesn’t sound to snarky. All I can think of is “Why?”
  • Haha 1
 I guess it could be down to the adapter and the user's experience . I'm happy with my 50 Apo lens used on the Gfx50r and would like to see some shots taken with the 35 apo as well .
Best
JM
its fun, and the images are very nice.
GFX50R + Leitz Elmar 35mm LTM [1946]
I am using the APO 50 on the 100s with the Novoflex adapter and find minimal vignetting as well.  Pictures are sharp at f2 (easy to focus on the 100s with magnification/peak focusing). As for the "why",  I am able to get 95-102MP of files which allow better printing and also allows me to supplement my GF lens line with my M lenses.  Note: I did not get the same minimal vignetting with the 35 AA; 50/1.0; 75/1.4 but was able to get 60-70 MP files after cropping.  Still need to shoot more to see if the character of the lens holds up.
  • 1 year later...
