TEBnewyork Posted August 26, 2007 Share #1 Posted August 26, 2007 Advertisement (gone after registration) When working in color I am shooting DNG only. When working in B&W I like seeing the B&W's on the LCD so I'm using DNG + jpeg. For others doing the same and using Lightroom are you: Using the basic or fine jpeg? Importing the jpeg into Lightroom or just the DNG? If you don't import the jpeg do you just trash it or keep it on a backup drive Thanks, Terry Link to post Share on other sites More sharing options...
Advertisement Posted August 26, 2007 Posted August 26, 2007 Hi TEBnewyork, Take a look here M8/Lightroom B&W workflow. I'm sure you'll find what you were looking for!
volkerhopf Posted August 26, 2007 Share #2 Posted August 26, 2007 Since there is not so much difference between fine and basic with respect to space needed I use fine. I do only import the DNG and dump the JPEG. I change the colour previews into BW after the import, because I always forget to set the import to BW. Regards Volker Link to post Share on other sites More sharing options...
guy Posted August 26, 2007 Share #3 Posted August 26, 2007 Much the same workflow as Volker. I agree it's really useful to visualise the scene in B&W on capture, so leave the JPEG set to "fine" to better check your focus if you need to. Then on import, dump the JPEGs and keep the DNGs. Set up a B&W conversion that works for you in Lightroom (with good basic contrast settings, maybe a touch of capture sharpening if you use it etc). Then you can save that as a preset (mine's called "basic B&W conversion) and, on import of your "B&W" DNGs, select it within the import dialogue. (This is what Volker says he always forgets to do!) That way, you need never see your DNGs in colour, and you can tweak away from the basic B&W conversion once they're in the program. Link to post Share on other sites More sharing options...
carstenw Posted August 26, 2007 Share #4 Posted August 26, 2007 I believe that Lightroom will ignore the JPGs, perhaps you need to set "Ignore Duplicates" to on or something. Link to post Share on other sites More sharing options...
TEBnewyork Posted August 26, 2007 Author Share #5 Posted August 26, 2007 Much the same workflow as Volker. I agree it's really useful to visualise the scene in B&W on capture, so leave the JPEG set to "fine" to better check your focus if you need to. Then on import, dump the JPEGs and keep the DNGs. Set up a B&W conversion that works for you in Lightroom (with good basic contrast settings, maybe a touch of capture sharpening if you use it etc). Then you can save that as a preset (mine's called "basic B&W conversion) and, on import of your "B&W" DNGs, select it within the import dialogue. (This is what Volker says he always forgets to do!) That way, you need never see your DNGs in colour, and you can tweak away from the basic B&W conversion once they're in the program. Perfect. Thank you Volker and Guy. The missing link for me was not doing the preset when importing them and it was feeling strange to do everything B&W and then have the DNG pop up in color in Lightroom. Link to post Share on other sites More sharing options...
