Wonder whether anyone could help with how to correct purple fringing in Lightroom.
In the past, I have successfully been able to remove purple fringing using the correction pipette in photos taken with the Noctiluxes 50mm/f095 and 75mm/f1.25, but have had no success with the Summilux-M 90mm/f1.5.
The Lightroom seems to be missing the lens profile for the Summilux, and therefore the pipette does not work.
Is there a way around, without the lens profile, for correcting the purple fringing ?
Thank you !
This time the pipette worked in Manual mode!
I had tried the manual mode previously, but gotten the remark: "Cannot set purple or green fringe color ".
Today, repeated tries gave varying results, sometimes the pipette worked, but about half of the attempts resulted in the above remark !?
a) for the correction of longitudinal CA no lens profile is needed.
Again: it makes absolutely no difference if there is a profile available or not here.
The profiles are for lateral CA, vignetting and distortion only.
b) depending on how distinct the fringing is the pipette may work better or worse.
A sample image where it didn't work would be really helpful here.
If you are not sure what type of CA you are dealing with maybe have a look here first to determine:
https://phillipreeve.net/blog/lens-aberrations-explained-part-1/#Chromatic_Aberrations
Edited by BastianK
